Nextcloud version (eg, 12.0.2):15.0.0.10
Operating system and version (eg, Ubuntu 17.04): linux (shared hosting)
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.37
PHP version (eg, 7.1): 7.2
Using the web interface, I cannot see/restore previous versions of my files. I know they exist, since I can see them in nextcloud-data/username/files_versions folder, but when I click on “Versions” from the “details” screen of a particular file, nothing happens.
Using Firefox debugging console, I get the following message (similar in Chrome console) at the exact moment I click on “Versions”:
**`TypeError: this.sync is not a function** core.js:2101:14
fetch https://XXX/core/vendor/core.js:2101:14
nextPage https://XXX/index.php/js/files_versions/merged.js:270:4
setFileInfo https://XXX/index.php/js/files_versions/merged.js:360:5
selectTab https://XXX/index.php/js/files/merged-index.js:9972:4
_onClickTab https://XXX/index.php/js/files/merged-index.js:9876:4
_onClickTab self-hosted:975:17
dispatch https://XXX/core/vendor/core.js:3:6414
add/r.handle https://XXX/core/vendor/core.js:3:3224
Is this the first time you’ve seen this error? (Y/N): Y, I know that versioning used to work since I have used it in the past. I do not remember if I have used it successfully after the 15.0.0 upgrade.
- Create a file
- Make a change so a new version is created
- In the web interface, click on Details -> Versions
Nothing relevant
'instanceid' => 'XXX',
'passwordsalt' => 'XXX',
'secret' => 'XXX',
0 => 'XXX',
'datadirectory' => '/home/secondes/nextcloud-data',
'overwrite.cli.url' => 'XXX',
'version' => '15.0.0.10',
'dbname' => 'XXX',
'dbhost' => 'localhost',
'dbuser' => 'XXX',
'dbpassword' => 'XXX',
'logtimezone' => 'UTC',
'debug' => false,
'updater.secret' => 'XXX',
'enable_certificate_management' => false,
'mail_smtpmode' => 'smtp',
'mail_domain' => 'XXX',
'theme' => '',
'loglevel' => 2,
'versions_retention_obligation' => 'auto',
'mail_smtphost' => 'XXX',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => 'XXX',
'mail_smtppassword' => 'XXX',
'mail_smtpsecure' => 'ssl',
