Sorry to hear youâre facing problems ![]()
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
My fault:
I stalled âNUT Network UPS Toolsâ
and then move it off to another computer and well removed NUT server and you guest if nextcloudâs âNextcloud All-in-One Interfaceâ and i get error
Open Nextcloud AIO Interface ![]()
"Unable to connect
An error occurred during a connection to 192.168.1.99:8080. "
Click here for more infos on this feature (e.g. also on how to change the link in the button)
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can ![]()
Nextcloud version _, 27.1.3
Operating system and version _
Ubuntu 22.04.3 LTS (GNU/Linux 5.15.0-91-generic x86_64)
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
Do not know?
âŚ
it looks like i have removed somthing with Apache and stops nextcloud from loading the AIO interface
Is this the first time youâve seen this error? (Y/N):
Yes it is
- tryed to stop AIO and reload it but
sudo docker stop nextcloud-aio-mastercontaine
sudo docker status nextcloud-aio-mastercontainer
did not stopi ran
sudo docker rm nextcloud-aio-mastercontainer
"CONTAINER ID NAME CPU % MEM USAGE / LIMIT MEM % NET I/O BLOCK I/O PIDS
9b90fd14ec42 nextcloud-aio-mastercontainer 0.00% 0B / 0B 0.00% 0B / 0B 0B / 0B 0
went back to my note Been some time been running very good here
that is where the commands came from -
log
Error PHP Declaration of Elastic\Elasticsearch\Response\Elasticsearch::withStatus(int $code, string $reasonPhrase = ââ): Psr\Http\Message\ResponseInterface must be compatible with Psr\Http\Message\ResponseInterface::withStatus($code, $reasonPhrase = ââ) at /var/www/html/custom_apps/fulltextsearch_elasticsearch/vendor/elasticsearch/elasticsearch/src/Traits/MessageResponseTrait.php#87
Error notifications GuzzleHttp\Exception\ConnectException: cURL error 6: Could not resolve host: push-notifications.nextcloud.com (see libcurl - Error Codes) for https://push-notifications.nextcloud.com/notifications
Error files_antivirus Not Checked. No matching rule for response . Please check antivirus rules configuration. File: 56855 Account: john Path: /john/files/Computer_Stuff/Amazon_Fire_Table_10plus/FTB_V26.1_Portable.zip
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
I was going to reinstall or switch to bata or ???
can i use a BACKUP to go back and fix it?
Also i would like to say the system is working with any problems for users
i know i should know i should not of did this âŚany help so i dont lose all my DATA
thanks for you help
John G.
