Hello to all
This is what happens to me and I think it is important to find a solution:
If you try to move a file or folder from an external read-only file system (SMB for example), an error is generated but the file is âphysicallyâ moved (copied).
Vers. 11.0.2 / 3
Case 1
- Create an external storage (SMB / CIFS read only)
- move a file from the external storage to the user folder (files)
- An error is generated (can not move âŠ)
- Run âocc files: scan userâ or simply âls user / filesâ and the file is in the user folder
Case 2
- Create an external storage (SMB / CIFS) with two folders, one read-only and one read and write
- Drag & drop a file from the read-only folder to the read and write folder
- Navigate to the samba filesystem in the read and write folder, the file is there
Of course this is because I can read the file (and then copy it) but I can not delete it.
Also, due to the error, the file is not visible from the interface if you are not running âocc files: scanâ
Unfortunately this is a situation that could easily occur in office environments (a read-only filesystem could be used for modules, templates, etc.)
I warned my users not to do this, but itâs not a good solution âŠ
