I have ncp installed on a debian64 server and I’m trying o move my datadir to a cifs mount.
I have edited the fstab file with the following line and the mount it’s working ok
\192.168.0.101/Nextcloud /media/nextcloud/data cifs username=XXX,pasword=XXX,uid=33,gid=33;dir_mode=0770,filemode=0770,iocharset=utf8,sec=ntlm, 0 0
But when I try to move datadir with nc-datadir command from the web I obtain the following message:
Only ext/btrfs filesystems can hold the data directory
I have surfed the web from a fix to this solution but I haven’t find anything that solves the problem.
I don’t know if cifs mounting is the better approach or maybe I should try NFS, my data is in a WD mycloud NAS. I am open to your suggestions.
I am quite newbie in linux so a step by step guide will be very helpfull.
Thanks for your support in advance
