After one of the last updates nextcloud mounted the wrong drives to the wrong /media/USBdrive
, and now even mounted USBdrive -> /media/USBdrive1 which doesn`t make much sense.
So I have a SSD /dev/sda1 called myCloudDrive which should be mounted to /media/USBdrive
And an HDD called zexternalhdd which should be mounted to /media/USBdrive1
ls of /media
gives me
fritz@nextcloudpi:/media$ ls -al
total 28
drwxr-xr-x 4 root root 4096 Apr 8 19:56 .
drwxr-xr-x 22 root root 4096 Nov 4 15:02 ..
lrwxrwxrwx 1 root root 16 Apr 8 19:56 USBdrive -> /media/USBdrive1
drwxr-xr-x 3 root root 4096 Apr 8 03:00 USBdrive1
drwxr-xr-x 1 root root 60 Dec 5 11:10 myCloudDrive
Automount enabled, no settings changed until this happened.
lsblk:
fritz@nextcloudpi:/media$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 465.8G 0 disk
`-sda1 8:1 0 465.7G 0 part /media/myCloudDrive
mmcblk1 179:0 0 59.7G 0 disk
`-mmcblk1p1 179:1 0 59G 0 part /
zram0 253:0 0 50M 0 disk /var/log
zram1 253:1 0 249.6M 0 disk [SWAP]
zram2 253:2 0 249.6M 0 disk [SWAP]
zram3 253:3 0 249.6M 0 disk [SWAP]
zram4 253:4 0 249.6M 0 disk [SWAP]
zram5 253:5 0 249.6M 0 disk [SWAP]
sometimes my external hdd doesn’t show up for some reason, like in this case.
It would be perfect to get this working again, and prevent it from happening again, maybe by permanently assigning the drives to the folders.
