example
longer
example
here
Nextcloud version: 21.0.2
Operating system and version: CentOs 7.9
Apache or nginx version: Apache 2.4.6
PHP version: 7.4.25
Is this the first time you’ve seen this error?: Y
Perform operation which include more than 1000 expressions.
The output of your config.php file in /var/www/html/nextcloud/config
'passwordsalt' => '*******',
'secret' => '*******',
0 => '*******',
1 => '*******',
'datadirectory' => '/var/nc_data/data',
'version' => '21.0.2.1',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '*******',
'dbpassword' => '*******',
'instanceid' => '*******',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'log_type' => 'file',
'loglevel' => '2',
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'log_rotate_size' => '10485760',
'remember_login_cookie_lifetime' => '3600',
'trashbin_retention_obligation' => 'auto, 15',
'versions_retention_obligation' => 'auto, 31',
'defaultapp' => 'apporder',
'theme' => '',
'enable_previews' => false,
'aiio_plf_instance_id' => '*******',
'data-fingerprint' => '*******',
'mail_from_address' => '*******',
'mail_smtpmode' => 'smtp',
'mail_domain' => '*******',
'mail_smtphost' => '*******',
'mail_smtpport' => '25',
'mail_smtpauth' => 1,
'mail_smtpname' => '******',
'mail_smtppassword' => '****,
Log in nextcloud.log
"reqId": "YaoTU5yCDmoiVtDypEa9fQAAAJY",
"level": 3,
"time": "2021-12-03T12:53:40+00:00",
"remoteAddr": "49.205.113.96",
"user": "OSM_02",
"app": "core",
"method": "POST",
"url": "/apps/aiio_gexp_app/datasets/bulk/export",
"message": {
"Exception": "Doctrine\\DBAL\\Query\\QueryException",
"Message": "More than 1000 expressions in a list are not allowed on Oracle.",
"Code": 0,
"Trace": [
"file": "/var/www/html/nextcloud/apps/aiio_gexp_app/lib/Db/DatasetMapper.php",
"line": 253,
"function": "execute",
"class": "OC\\DB\\QueryBuilder\\QueryBuilder",
"type": "->"
"line": 178,
"function": "fetchDatasets",
"class": "OCA\\AIIO_GExP_App\\Db\\DatasetMapper",
"type": "->"
"file": "/var/www/html/nextcloud/apps/aiio_gexp_app/lib/Service/DatasetExport/DatasetExportService.php",
"line": 137,
"function": "getEnabled",
"type": "->"
"file": "/var/www/html/nextcloud/apps/aiio_gexp_app/lib/Controller/DatasetApiController.php",
"line": 597,
"function": "bulkExportRequest",
"class": "OCA\\AIIO_GExP_App\\Service\\DatasetExport\\DatasetExportService",
"type": "->"
"file": "/var/www/html/nextcloud/lib/private/AppFramework/Http/Dispatcher.php",
"line": 218,
"function": "bulkExport",
"class": "OCA\\AIIO_GExP_App\\Controller\\DatasetApiController",
"type": "->"
"line": 127,
"function": "executeController",
"class": "OC\\AppFramework\\Http\\Dispatcher",
"type": "->"
"file": "/var/www/html/nextcloud/lib/private/AppFramework/App.php",
"line": 157,
"function": "dispatch",
"type": "->"
"file": "/var/www/html/nextcloud/lib/private/Route/Router.php",
"line": 302,
"function": "main",
"class": "OC\\AppFramework\\App",
"type": "::"
"file": "/var/www/html/nextcloud/lib/base.php",
"line": 993,
"function": "match",
"class": "OC\\Route\\Router",
"type": "->"
"file": "/var/www/html/nextcloud/index.php",
"line": 37,
"function": "handleRequest",
"class": "OC",
"type": "::"
"File": "/var/www/html/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php",
"Line": 268,
"CustomMessage": "More than 1000 expressions in a list are not allowed on Oracle."
"userAgent": "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/94.0.4606.54 Safari/537.36",
"version": "21.0.2.1",
"id": "61aa137ab81ab"
