Monitor cutting off the display with NextcloudPI v1.55.4 on RaspberryPi 5... Any fix?
I have made some research through Google and ChatGPT and I am not really getting anywhere with this issue.
    • 30.0.5.1 (NextcloudPI v1.55.4 )
    • OS Armbian-unofficial 24.8.2 Bookworm \l . 6.6.45-current-bcm2712 (aarch64)
    • Always
    • AIO
    • no
When I connect to my NextcloudPI Raspberry Pi 5 through HDMI part of the screen is cut off by the screen (old Samsung 245T pc screen).
Do we have a way to address this? Reason why I am trying to make this work is because I need to do some network related work on the NextcloudPi and if I ever get disconnected I want to be able to work my way out of the mess by connecting physically to the device.
  1. Connect to the device using an HDMI cable
No clue, but some hints:
  • video/hdmi configure I would start at raspi docu
  • then take a look at armbian - try armbian-config
  • breaking ssh connections can get less painfull using tmux multiplexer
  • network configuring on armbian - keep netplan in mind
  • if you want wlan, it is a firmware thing you find some notes on armbian forum
  • last issue on ncp github seems to have a nice workaround
    Good luck.
This is not nextcloud realted but Raspberry Pi related.
It was happen even many years ago with my old Raspi 1 and Raspi 2. I don’t use those anymore and honestly don’t remember the solution. But solution i fond i fond with google and was Raspberry’s OS relate to be found in that config files. So do more google search.
