Module smbclient is not installed
I am trying to connect an external hard drive to nextcloud. I’m using a microcomputer, I can already connect and login to nextcloud safely, but there is a problem with the external storage.
The “smbclient” module is not installed, mounting ““SMB/CIFS”, “SMB/CIFS using login credentials”” is not possible. Please contact your system administrator.
I have searched all forums, installed everything I can. samba and smb-clinent etc. But the result is still the same. although the console shows that smbclient is installed and updated.
Thank you in advance for your help!
Hi @Olga_Bondarenko
Here the php module php-smbclient is meant that have to be installed for your php version.
Much and good luck,
ernolf
Unfrotunatelly php-smbclient is already the newest version
Perhaps a misunderstanding. smbclient is not php-smbclient. Have you check both?
Ubuntu – Package Search Results -- smbclient
https://packages.ubuntu.com/search?keywords=php-smbclient
could you please post the output of
awk '/php/{print$2}' <(dpkg -l)
and
grep php <(update-alternatives --get-selections)
and if your webserver is apache2
grep mpm <(sudo apachectl -M 2>/dev/null)
ernolf
Yes, unfortunatelly all checked
The output of
awk ‘/php/{print$2}’ <(dpkg -l)
and
Thank you all for your attention
Hello
I have exactly the same problem
Is there a solution?
Hey @Olga_Bondarenko and @BallPic,
see How to add samba shares and local shares · nextcloud-snap/nextcloud-snap Wiki · GitHub
