Nextcloud version (eg, 20.0.5): 24.0.0 dev (I see this in version.php, the value of OC_VersionString variable)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.41
PHP version (eg, 7.4): 8.0.17
As said here, I’m trying to run this command:
make build-js
But I get the following error in the terminal:
ERROR in ./core/src/OC/contactsmenu/list.handlebars
Module build failed (from ./node_modules/handlebars-loader/index.js):
Error: Parse error on line 13:
...}</a></div>{{/if}}
Expecting 'CONTENT', 'COMMENT', 'OPEN_BLOCK', 'OPEN_INVERSE', 'OPEN_ENDBLOCK', 'OPEN', 'OPEN_UNESCAPED', 'OPEN_PARTIAL', got 'EOF'
at Parser.parseError (/home/projects/files/node_modules/handlebars-loader/node_modules/handlebars/dist/cjs/handlebars/compiler/parser.js:107:11)
at Parser.parse (/home/projects/files/node_modules/handlebars-loader/node_modules/handlebars/dist/cjs/handlebars/compiler/parser.js:159:22)
at HandlebarsEnvironment.parse (/home/projects/files/node_modules/handlebars-loader/node_modules/handlebars/dist/cjs/handlebars/compiler/base.js:12:17)
at precompile (/home/projects/files/node_modules/handlebars-loader/node_modules/handlebars/dist/cjs/handlebars/compiler/compiler.js:435:17)
at HandlebarsEnvironment.hb.precompile (/home/projects/files/node_modules/handlebars-loader/node_modules/handlebars/dist/cjs/handlebars.js:22:12)
at generateTemplateExport (/home/projects/files/node_modules/handlebars-loader/index.js:66:80)
at Object.module.exports (/home/projects/files/node_modules/handlebars-loader/index.js:36:10)
@ ./core/src/OC/contactsmenu.js 244:10-51
@ ./core/src/OC/index.js 36:0-42 98:16-28
@ ./core/src/login.js 27:0-28
webpack 5.70.0 compiled with 1 error and 1 warning in 51616 ms
make: *** [Makefile:14: build-js] Error 1
I tried running make command both in docker host and docker container but got the same error.
After running this command, I now see that website.com/apps/dashboard does not load.
Is this the first time you’ve seen this error? Yes
cd /home/projects/filesmake build-js
The URL https://website.com/apps/dashboard does not load to have any output in web.
'debug' => true,
'instanceid' => 'oce6illk00p9',
'passwordsalt' => '2WM2utukJQ02TMMdVYNknImgVAaHba',
'secret' => 'HE59/8B8t2lJ+ThFv6QkPtQ98O9MCRAF5+121T+NEw+xS8EG',
0 => 'pz2.ir',
'version' => '24.0.0.5',
'overwrite.cli.url' => 'https://website.com/',
'dbname' => 'db',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'pass',
// # logging
// "log_type" => "file",
// "logfile" => "/var/log/nextcloud",
// "loglevel" => 3,
// "logdateformat" => "F d, Y H:i:s",
There are no logs in error.log
There are no logs after I did activated log section in config.php.
