example
longer
example
here
Nextcloud version 19.0.2:
Operating system and version Ubuntu 18.04:
Apache or nginx version Apache 2.4.25:
PHP version 7.4:
The event log in settings / admin / logging is frequently filled with this error.
I have already read about this error articles but I cannot find a possible solution.
Could you give me some help?
root@cloud:~# php -i | grep apc
/etc/php/7.4/cli/conf.d/20-apcu.ini,
/etc/php/7.4/cli/conf.d/25-apcu_bc.ini
apc
apcu
apc.coredump_unmap => Off => Off
apc.enable_cli => Off => Off
apc.enabled => On => On
apc.entries_hint => 4096 => 4096
apc.gc_ttl => 3600 => 3600
apc.mmap_file_mask => no value => no value
apc.preload_path => no value => no value
apc.serializer => php => php
apc.shm_segments => 1 => 1
apc.shm_size => 32M => 32M
apc.slam_defense => Off => Off
apc.smart => 0 => 0
apc.ttl => 0 => 0
apc.use_request_time => On => On
[PHP] Error: Module 'apcu' already loaded at Unknown#0
GET /ocm-provider/
from xxx.xxx.xxx.xxx by myuser at 2020-09-03T15:41:51-04:00
"url.dominio.net",
"1.1.1.1"
"dbtype": "mysql",
"version": "19.0.2.2",
"overwrite.cli.url": "https:\/\/url.dominio.net",
"htaccess.RewriteBase": "\/",
"dbport": "",
"mysql.utf8mb4": true,
"skeletondirectory": "",
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_smtpauth": 1,
"mail_smtpauthtype": "LOGIN",
"mail_smtpport": "25",
"default_language": "es",
"ldapIgnoreNamingRules": false,
"redis": {
"port": 6379
