Nextcloud version (eg, 20.0.5): 19.0.13.1
Operating system and version (eg, Ubuntu 20.04): DSM 6.2.4 update 7 (synology)
Apache or nginx version (eg, Apache 2.4.25): 2.4
PHP version (eg, 7.4): 5.6.11
I can’t no longer log into my nextcloud server, since I launch the upgrade.
- Update from web interface
- Block into “Maintenance Mode”
- I change the line ‘mantenance’ => false, # in config.php and fall into “server internal error”
- When i turn back the line ‘mainteance’ => true, # I keep the same error
- I reboot but still get the same error.
{"reqId":"ZhoRBEy38I98uMYOjTdz","level":3,"time":"2020-01-09T12:03:43+00:00","remoteAddr":"192.168.1.29","user":"--","app":"PHP","method":"POST","url":"\/nextcloud\/index.php","message":"mkdir(): Permission denied at \/volume1\/web\/nextcloud\/lib\/private\/Setup.php#302","userAgent":"Mozilla\/5.0 (Windows NT 10.0; Win64; x64; rv:72.0) Gecko\/20100101 Firefox\/72.0","version":""}
{"reqId":"jVPugeP80cdbgopHkCbt","level":3,"time":"2023-06-02T07:28:58+00:00","remoteAddr":"192.168.1.254","user":"--","app":"PHP","method":"GET","url":"/status.php","message":{"Exception":"Error","Message":"touch(): Utime failed: Permission denied at /volume1/web/nextcloud/lib/private/Config.php#242","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"touch(): Utime failed: Permission denied","/volume1/web/nextcloud/lib/private/Config.php",242,{"content":"<?php\n$CONFIG = array (\n 'instanceid' => 'ocw5cc7isn17',\n);\n"}]},{"file":"/volume1/web/nextcloud/lib/private/Config.php","line":242,"function":"touch","args":["/volume1/web/nextcloud/config/config.php"]},{"file":"/volume1/web/nextcloud/lib/private/Config.php","line":134,"function":"writeData","class":"OC\\Config","type":"->","args":[]},{"file":"/volume1/web/nextcloud/lib/private/SystemConfig.php","line":132,"function":"setValue","class":"OC\\Config","type":"->","args":["instanceid","ocw5cc7isn17"]},{"file":"/volume1/web/nextcloud/lib/private/legacy/OC_Util.php","line":1168,"function":"setValue","class":"OC\\SystemConfig","type":"->","args":["instanceid","ocw5cc7isn17"]},{"file":"/volume1/web/nextcloud/lib/base.php","line":420,"function":"getInstanceId","class":"OC_Util","type":"::","args":[]},{"file":"/volume1/web/nextcloud/lib/base.php","line":649,"function":"initSession","class":"OC","type":"::","args":[]},{"file":"/volume1/web/nextcloud/lib/base.php","line":1091,"function":"init","class":"OC","type":"::","args":[]},{"file":"/volume1/web/nextcloud/status.php","line":37,"args":["/volume1/web/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/volume1/web/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/113.0","version":""}
{"reqId":"jVPugeP80cdbgopHkCbt","level":3,"time":"2023-06-02T07:28:58+00:00","remoteAddr":"192.168.1.254","user":"--","app":"PHP","method":"GET","url":"/status.php","message":{"Exception":"Error","Message":"fopen(/volume1/web/nextcloud/config/config.php): failed to open stream: Permission denied at /volume1/web/nextcloud/lib/private/Config.php#243","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"fopen(/volume1/web/nextcloud/config/config.php): failed to open stream: Permission denied","/volume1/web/nextcloud/lib/private/Config.php",243,{"content":"<?php\n$CONFIG = array (\n 'instanceid' => 'ocw5cc7isn17',\n);\n"}]},{"file":"/volume1/web/nextcloud/lib/private/Config.php","line":243,"function":"fopen","args":["/volume1/web/nextcloud/config/config.php","r+"]},{"file":"/volume1/web/nextcloud/lib/private/Config.php","line":134,"function":"writeData","class":"OC\\Config","type":"->","args":[]},{"file":"/volume1/web/nextcloud/lib/private/SystemConfig.php","line":132,"function":"setValue","class":"OC\\Config","type":"->","args":["instanceid","ocw5cc7isn17"]},{"file":"/volume1/web/nextcloud/lib/private/legacy/OC_Util.php","line":1168,"function":"setValue","class":"OC\\SystemConfig","type":"->","args":["instanceid","ocw5cc7isn17"]},{"file":"/volume1/web/nextcloud/lib/base.php","line":420,"function":"getInstanceId","class":"OC_Util","type":"::","args":[]},{"file":"/volume1/web/nextcloud/lib/base.php","line":649,"function":"initSession","class":"OC","type":"::","args":[]},{"file":"/volume1/web/nextcloud/lib/base.php","line":1091,"function":"init","class":"OC","type":"::","args":[]},{"file":"/volume1/web/nextcloud/status.php","line":37,"args":["/volume1/web/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/volume1/web/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/113.0","version":""}
{"reqId":"jVPugeP80cdbgopHkCbt","level":3,"time":"2023-06-02T07:28:58+00:00","remoteAddr":"192.168.1.254","user":"--","app":"PHP","method":"GET","url":"/status.php","message":{"Exception":"Error","Message":"chmod(): Operation not permitted at /volume1/web/nextcloud/lib/private/Config.php#246","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"chmod(): Operation not permitted","/volume1/web/nextcloud/lib/private/Config.php",246,{"content":"<?php\n$CONFIG = array (\n 'instanceid' => 'ocw5cc7isn17',\n);\n","filePointer":false}]},{"file":"/volume1/web/nextcloud/lib/private/Config.php","line":246,"function":"chmod","args":["/volume1/web/nextcloud/config/config.php",416]},{"file":"/volume1/web/nextcloud/lib/private/Config.php","line":134,"function":"writeData","class":"OC\\Config","type":"->","args":[]},{"file":"/volume1/web/nextcloud/lib/private/SystemConfig.php","line":132,"function":"setValue","class":"OC\\Config","type":"->","args":["instanceid","ocw5cc7isn17"]},{"file":"/volume1/web/nextcloud/lib/private/legacy/OC_Util.php","line":1168,"function":"setValue","class":"OC\\SystemConfig","type":"->","args":["instanceid","ocw5cc7isn17"]},{"file":"/volume1/web/nextcloud/lib/base.php","line":420,"function":"getInstanceId","class":"OC_Util","type":"::","args":[]},{"file":"/volume1/web/nextcloud/lib/base.php","line":649,"function":"initSession","class":"OC","type":"::","args":[]},{"file":"/volume1/web/nextcloud/lib/base.php","line":1091,"function":"init","class":"OC","type":"::","args":[]},{"file":"/volume1/web/nextcloud/status.php","line":37,"args":["/volume1/web/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/volume1/web/nextcloud/lib/private/Log/ErrorHandler.php","Line":91,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/113.0","version":""}
{"reqId":"jVPugeP80cdbgopHkCbt","level":3,"time":"2023-06-02T07:28:58+00:00","remoteAddr":"192.168.1.254","user":"--","app":"remote","method":"GET","url":"/status.php","message":{"Exception":"OC\\HintException","Message":"Can't write into config directory!","Code":0,"Trace":[{"file":"/volume1/web/nextcloud/lib/private/Config.php","line":134,"function":"writeData","class":"OC\\Config","type":"->","args":[]},{"file":"/volume1/web/nextcloud/lib/private/SystemConfig.php","line":132,"function":"setValue","class":"OC\\Config","type":"->","args":["instanceid","ocw5cc7isn17"]},{"file":"/volume1/web/nextcloud/lib/private/legacy/OC_Util.php","line":1168,"function":"setValue","class":"OC\\SystemConfig","type":"->","args":["instanceid","ocw5cc7isn17"]},{"file":"/volume1/web/nextcloud/lib/base.php","line":420,"function":"getInstanceId","class":"OC_Util","type":"::","args":[]},{"file":"/volume1/web/nextcloud/lib/base.php","line":649,"function":"initSession","class":"OC","type":"::","args":[]},{"file":"/volume1/web/nextcloud/lib/base.php","line":1091,"function":"init","class":"OC","type":"::","args":[]},{"file":"/volume1/web/nextcloud/status.php","line":37,"args":["/volume1/web/nextcloud/lib/base.php"],"function":"require_once"}],"File":"/volume1/web/nextcloud/lib/private/Config.php","Line":250,"Hint":"This can usually be fixed by giving the webserver write access to the config directory.","CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/113.0","version":""}
'instanceid' => 'oc3ljs69sbvb',
'passwordsalt' => 'jdnFefZKk8uoQLKiXEZHoFJYGmfWR+',
'secret' => 'qRiqRv12gSreL4bKsuwWSnuKZl4aIjHOFZr4TbSGFZFxeooA',
0 => '192.168.XXX.XXX',
1 => 'XXX.XXX.XXX.XXX',
2 => '###########.online',
'datadirectory' => '/volume1/NextCloud',
'version' => '19.0.13.1',
'overwrite.cli.url' => 'https://192.168.XXX.XXX/nextcloud',
'dbname' => '###########',
'dbhost' => '127.0.0.1:3307',
'dbuser' => 'oc_??????????????',
'dbpassword' => 'oK4XBsWnhSHeCQ143fN67v6Z6dxlMj',
'memcache.local' => '\\OC\\Memcache\\ArrayCache',
'maintenance' => true,
'twofactor_enforced' => 'true',
'mail_from_address' => '########',
'mail_smtpmode' => 'smtp',
'mail_domain' => '########',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.live.com',
'mail_smtpport' => '587',
'mail_smtpname' => '###############',
'mail_smtppassword' => '############',
'mail_smtpsecure' => 'tls',
'updater.secret' => '$2y$10$S4SYHz9fFpH7BpChHPPXAe1XYuagqaae9TGKHjZdFgpYG/TFCRieC',
'theme' => '',
'loglevel' => 0,
I don’t paste the other log from nginx because I don’t think there is relevant informations.
Could you give me a solution to revert back to a previous version or to exit this stuck state please ?
I can add that I can’t use the occ commands because of the version of php which is 5.6.11.
Best regards !
