Missing placeholder / hint text in "Run script" action (workflow_script) in Flow UI – Nextcloud 32
Hi everyone,
I’m currently using Nextcloud AIO with the workflow_script app to run external scripts when a file is created or updated.
However, I noticed something different from the documentation and the screenshots provided by the app developer.
In the documentation examples, when selecting “Run script” in the Flow configuration, there is usually a placeholder / hint in the input field showing how to enter the script path and variables (for example a sample command with placeholders like %f or similar variables).
On my installation, the Flow action can still be configured, but the placeholder / hint text does not appear at all in the command input field, so it is unclear how exactly the command should be formatted.
Environment
  • OS (host): Ubuntu 25.04 (plucky)
  • Kernel: Linux 6.14.0-35-generic x86_64
  • Deployment: Nextcloud All-in-One (AIO) in Docker
  • Docker containers (relevant):
    • nextcloud-aio-mastercontainer → image: ghcr.io/nextcloud-releases/all-in-one:latest
      • Ports: 80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp
    • nextcloud-aio-apache → image: ghcr.io/nextcloud-releases/aio-apache:latest
      • Ports: 80/tcp, 127.0.0.1:11000->11000/tcp
    • nextcloud-aio-nextcloud → image: ghcr.io/nextcloud-releases/aio-nextcloud:latest
      • Ports: 9000/tcp
    • nextcloud-aio-database → image: ghcr.io/nextcloud-releases/aio-postgresql:latest
      • Ports: 5432/tcp (internal)
    • nextcloud-aio-redis → image: ghcr.io/nextcloud-releases/aio-redis:latest
      • Ports: 6379/tcp (internal)
    • nextcloud-aio-talk → image: ghcr.io/nextcloud-releases/aio-talk:latest
      • Ports: 0.0.0.0:3478->3478/tcp, 0.0.0.0:3478->3478/udp, :::3478->3478/tcp, :::3478->3478/udp
    • plus other AIO containers: nextcloud-aio-imaginary, nextcloud-aio-whiteboard, nextcloud-aio-notify-push, nextcloud-aio-onlyoffice
  • Nextcloud version (from inside nextcloud-aio-nextcloud container):
    From php occ status:
    • installed: true
    • version: 32.0.6.1
    • versionstring: 32.0.6
    • maintenance: false
    • needsDbUpgrade: false
  • **PHP version (inside Nextcloud container):
    PHP 8.3.30 (cli) (NTS)
    Zend Engine v4.3.30 with Zend OPcache v8.3.30
  • Workflow-related apps (from occ app:list | grep -i workflow):
    - workflow_pdf_converter: 3.0.0
    - workflow_script: 3.0.0
    - workflow_script_ui_fix: 0.1.0
    - workflowengine: 2.14.0
  • Log file:
    data/nextcloud.log (exists, size ~250 KB)
If needed, I can provide specific log excerpts relevant to opening the Flow page or saving the Flow.
What I’m trying to do
I want to set up a Flow using the Workflow Script app so that Nextcloud will run a shell script when a file is created or updated.
According to the screenshots and documentation of the app, in the “Run script” action there should be a placeholder or example text in the input field showing how to specify the script path and placeholders (e.g. a sample command with %f etc.).
Actual behavior
  • I go to Administration → Flow and create a new Flow.
  • I configure for example:
    • Trigger: File created / File updated
    • Filter: Custom mimetype = text/plain
    • Action: Run script (from the workflow_script app)
  • The action shows a command input field, but:
    • There is no placeholder / hint text inside the input field.
    • It is just an empty field without any example of how to write the command or which variables (like %f) are available.
So the workflow can be created, but I do not see the same helpful placeholder that is visible in the app’s documentation.
Expected behavior
  • When choosing the “Run script” action, I expect the input field to show a placeholder / hint that indicates:
    • a sample script path (e.g. /path/to/script.sh %f), and/or
    • which placeholder variables are available (like %f for the file, etc.).
  • This would make it clear how to format the command.
Questions
  1. Is this missing placeholder/hint expected behavior in recent versions of Nextcloud or the workflow_script app?
  2. Could this be related to:
    • my Nextcloud version (32.0.6),
    • the workflow_script version (3.0.0),
    • the additional workflow_script_ui_fix app,
    • or some missing configuration / dependency?
  3. Is there a known way to restore or enable the placeholder/hint in the Run script input field?
If screenshots or log snippets would help, I can provide them as well. Thanks in advance for any guidance!
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
    • replace me
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
To see the available variable, you need to click on the small arrow behind the word “documentation” which is shown below the path field:
grafik
I’m personally not a fan of calling scripts via a variable, instead I would recommend to use an absolute path, like “<path-to-the script-you want-to-call>/your-script.sh "%a" "%e" "%f" "%i" "%n" "%o" "%x"”, and append the variables you want to parse to the script.
BTW, you should search this forum for answer first before raising a new request :wink:
https://help.nextcloud.com/search?q=workflow_scripts%20%40j-ed
Here is a picture of what i’m facing
Somehow the path field is not shown on your server. It should look like this:
I would recommend to clear caches, change web browser etc. to find put what is suppressing the field.
