Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): 28.0.5
Operating system and version (eg, Ubuntu 20.04): Rocky Linux 9.3
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.57 (Rocky Linux)
PHP version (eg, 7.4): PHP 8.2.18 (cli) (built: Apr 9 2024 18:46:23) (NTS gcc x86_64)
Awhile back, I setup object storage (in this case, Minio) server on a different box as primary storage, and it was pretty laggy. I’m wondering if instead, I can simply use Minio (or any other object storage) only for user file storage rather than totally replacing the local file system config/cache/etc.
What I would like to do is retain a fast zippy NextCloud experience by having most system/config/cache/etc files remain on the NextCloud instance, while having user files (videos, my documents, etc) sitting elsewhere on an object storage server (e.g., Minio). I would like to do this so I can decouple the NextCloud engine from my personal data, to minimize the overall size of my NextCloud installation and help make it a little easier to backup/migrate.
Also, I realize I could simply mount an external storage folder, but an extra folder is a bit confusing for some users and annoying for myself. I would rather see a normal root folder in my personal file storage, which is already mapped to the remote bucket; It should be impossible to accidentally store personal files on the NC server by choosing the wrong folder.
Is this the first time you’ve seen this error? (Y/N): Not really an error. More like a request for config help. I experienced this a few major versions ago and have not tried it in the most recent version.
- Setup object storage server, somewhere away from the NextCloud instance
- Configure NextCloud to use the object storage as Primary Storage
- Note that the NextCloud experience in general seems to be laggy as all data is now on another server.
I no longer have this config, as I have not tried this for several major versions.
