I have already been using the mindmap app for sometime now - Today when I opened the mind maps - I see a blank dashboard with the following alert -
“The file is not a valid mind map file and may cause file corruption if you continue editing.”
If I go to Administration Settings → Logging and check the log - I see the following error messages -
[no app in context] Error: InvalidArgumentException: Dashboard widget with this id has already been registered at <>
- /var/www/nextcloud/lib/private/Dashboard/Manager.php line 94
OC\Dashboard\Manager->registerWidget()- /var/www/nextcloud/lib/private/Dashboard/Manager.php line 131
OC\Dashboard\Manager->loadLazyPanels()- /var/www/nextcloud/apps/dashboard/lib/Controller/DashboardController.php line 101
OC\Dashboard\Manager->getWidgets()- /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 225
OCA\Dashboard\Controller\DashboardController->index()- /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 133
OC\AppFramework\Http\Dispatcher->executeController()- /var/www/nextcloud/lib/private/AppFramework/App.php line 172
OC\AppFramework\Http\Dispatcher->dispatch()- /var/www/nextcloud/lib/private/Route/Router.php line 298
OC\AppFramework\App::main()- /var/www/nextcloud/lib/base.php line 1047
OC\Route\Router->match()- /var/www/nextcloud/index.php line 36
OC::handleRequest()GET /apps/dashboard/
from 127.0.0.1 by cerulean at 2022-12-24T13:21:02+00:00
Also I get the following issue -
[no app in context] Error: Cannot decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you.
PROPFIND /remote.php/dav/versions/cerulean/versions/35534
from 127.0.0.1 by cerulean at 2022-12-24T13:06:21+00:00
{“reqId”:“w3cxRTpMjiUV1jIVl6vC”,“level”:3,“time”:“2022-12-24T13:06:21+00:00”,“remoteAddr”:“127.0.0.1”,“user”:“cerulean”,“app”:“no app in context”,“method”:“PROPFIND”,“url”:“/remote.php/dav/versions/cerulean/versions/35534”,“message”:“Cannot decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you.”,“userAgent”:“Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36”,“version”:“25.0.2.3”,“data”:,“id”:“63a6fe05ec526”}
Can someone please help me resolve this ?
