Mimetypelist.js problems - Upgrading problem
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- core
	- INVALID_HASH
		- core/js/mimetypelist.js
Raw output
Array
    [core] => Array
            [INVALID_HASH] => Array
                    [core/js/mimetypelist.js] => Array
                            [expected] => 23a3fa45757b26795f5cf8f94d9e5bce76fc916288a6458679311b312c167adcf4158ccb2c5c3db791fa0b87703b6c5863afb6c9d790b8cbac5ab3ae8c3418fb
                            [current] => 86c1f1b719b65bf02b1dca9b061ef310c8dfface25c9ccfa243c4090665fa6f305d8a4143d7410350af27b1d9e14968c7d999a965d1e110bc674d30ed5dee4e8
I am trying to update from Nextcloud 22.2.3 to Nextcloud 22.2.5 but got this error on Overview tab, and when executing the Updater from GUI, cannot make backup … probably because of this error.
I got the same error after the update. Downloading the package from the website and copy the file to the location did not help.
Do you have onlyoffice installed. → BUG ( Integrity check fails for core/js/mimetypelist.js after upgrade to NC 23 · Issue #30732 · nextcloud/server · GitHub )
I did not encountered this error.
have you tried
occ maintenance:mimetype:update-js
Meanwhile I updated to e newer release and the error vanished. Thx anyway.
$ sudo -u www-data php occ maintenance:mimetype:update-js
mimetypelist.js is updated
$ sudo -u www-data php occ integrity:check-core
  - INVALID_HASH:
    - core/js/mimetypelist.js:
      - expected: 23a3fa45757b26795f5cf8f94d9e5bce76fc916288a6458679311b312c167adcf4158ccb2c5c3db791fa0b87703b6c5863afb6c9d790b8cbac5ab3ae8c3418fb
      - current: 86c1f1b719b65bf02b1dca9b061ef310c8dfface25c9ccfa243c4090665fa6f305d8a4143d7410350af27b1d9e14968c7d999a965d1e110bc674d30ed5dee4e8
occ seems that it cannot rewrite the file.
Maybe this is a bug or something …
Disabling ONLYOFFICE did not help at all…
It is advisable to manually replace the file from github source?
@DaniS updating with Updatr from nextcloud interface gets stuck at Creating Backup
Later on …
Solved the issue by downloading the .zip package closest to my release… eg. 22.2.3 i downloaded the 22.2.6 version of mimetypelist.js and replaced that original file fom my server. Everything worked!
As for the part where Creating Backup showed in Updating from web interface… a simple sudo chown -R www-data:www-data <nextcloud dir> solved the issue
remove the file and download the latest version then it works,
here are the commands just adjust your installation directory if you have it somewhere else
sudo rm /var/www/nextcloud/core/js/mimetypelist.js
sudo wget https://raw.githubusercontent.com/nextcloud/server/master/core/js/mimetypelist.js -P /var/www/nextcloud/core/js
You should always take the files from the tag of your version:
  1. open a terminal
  2. enter this code (check NC_DIR and HT_USER carefully beforehand):
HT_USER=www-data # change this if your ht user is different
NC_DIR=/var/www/nextcloud
nc_download_default() { local app_id=$1 file=$2 version_tag path=$2
    case "$app_id" in
        server) version_tag="v$(awk -F\' '/String/{gsub(/ /,"");$2=tolower($2);print $2}' "$NC_DIR/version.php")"   ;;
        *)      xml_f="$NC_DIR/apps/$app_id/appinfo/info.xml"
                version_tag="v$(xmlstarlet sel -B -t -v "//info/version" "$xml_f"|sed '2,$d')"
                path="apps/$app_id/$file"
    esac
    sudo -u $HT_USER curl -so $NC_DIR/$path https://raw.githubusercontent.com/nextcloud/$app_id/$version_tag/$file
nc_download_default server "core/js/mimetypelist.js"
sudo -u $HT_USER php $NC_DIR/occ integrity:check-core
This way you will have the correct file for your version on the right place.
You can integrate this function in your environment (e.g. add it to your ~/.bash_aliases) You can use it for missing files from within shipped apps as well, but then xmlstarlet must be installed.
Much and good luck,
ernolf
