I have a question about mimetype mapping on my NC 14 Installation. I want to create specific rules for CAD files on our Server. The CAD System uses the extension .prt, .asm and .drw for its files. But after every save it adds a number after the extension. For example examplepart.prt.1 and after the next save examplepart.prt.2 and so on. Is there a way to use wildcards in the Mimetype mapping. For example
“prt.*”: [“application/pro-e”]
Thank you in advance, for your help.
