So I tried to install a new instance of Nextcloud, and that seems to work fine. So now I need to migrate users and their data to the new installation. I only found advice on how to migrate a whole instance; can anyone please give some advice on how to migrate users and their data to a new instance?
Hi Jason… I’d like to migrate from a TruNAS NC Plugin to a fresh install in a Jail that allows updating OS and NC without danger of crashing. The DATA is already existing on a “cloud” folder on the TrueNAS system. Terabytes are already in there.
Does the procedure you outlined above work on my scenario? It’s a BSD 12.2 install, and works nicely. Haven’t instaled any users or data…
Have however already made the “Mount Points” and verified that the data appears in Nextcloud/Data …
root@localhost [(none)]> show databases;
| Database |
| information_schema |
| mysql |
| nextcloud | <= the existing db
| p49oz3bg | <= the db I wanted to use
| performance_schema |
| sys |
6 rows in set (0.01 sec)
I thought the restore from the other instance would populate nextcloud. Instead it just created a clone of itself. I should have known. Ugh! Is this fixable ?
Can I copy the config.php from the NC instance that uses the database (p49oz3bg) I want to use and just change the IP address… ?
