Nextcloud version (eg, 12.0.2): 15.0.2
Operating system and version (eg, Ubuntu 17.04): Raspbian buster
Apache or nginx version (eg, Apache 2.4.25): nginx 1.14.2
PHP version (eg, 7.1): PHP 7.2
If I add 'memcache.local' => '\OC\Memcache\APCu',
to my nextcloud config it makes my Nextcloud unusable until I remove the line again. There is this error on Nextcloud if I add it:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
- I added
to the config. - Refreshed my Nextcloud site.
\\Memcache\\Factory"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/ServerContainer.php","line":132,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":165,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Memcache\\Factory"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":114,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":117,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["MemCacheFactory"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/ServerContainer.php","line":132,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["MemCacheFactory"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/Server.php","line":1533,"function":"query","class":"OC\\ServerContainer","type":"->","args":["MemCacheFactory"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/Server.php","line":697,"function":"getMemCacheFactory","class":"OC\\Server","type":"->","args":[]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":118,"function":"OC\\{closure}","class":"OC\\Server","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":117,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["OC\\App\\AppManager"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/ServerContainer.php","line":132,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\App\\AppManager"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":165,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\App\\AppManager"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/3rdparty\/pimple\/pimple\/src\/Pimple\/Container.php","line":114,"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","line":117,"function":"offsetGet","class":"Pimple\\Container","type":"->","args":["AppManager"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/ServerContainer.php","line":132,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["AppManager"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/Server.php","line":1723,"function":"query","class":"OC\\ServerContainer","type":"->","args":["AppManager"]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/legacy\/app.php","line":342,"function":"getAppManager","class":"OC\\Server","type":"->","args":[]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/legacy\/app.php","line":113,"function":"getEnabledApps","class":"OC_App","type":"::","args":[]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/base.php","line":654,"function":"loadApps","class":"OC_App","type":"::","args":[["session"]]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/base.php","line":1068,"function":"init","class":"OC","type":"::","args":[]},{"file":"\/var\/www\/[hidden for privacy reasons]\/public_html\/index.php","line":40,"args":["\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/base.php"],"function":"require_once"}],"File":"\/var\/www\/[hidden for privacy reasons]\/public_html\/lib\/private\/Memcache\/Factory.php","Line":99,"Hint":"Is the matching PHP module installed and enabled?","CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/71.0.3578.98 Safari\/537.36","version":"15.0.2.0"}
'instanceid' => 'xxxxxxxxxxxxxxx',
'passwordsalt' => 'xxxxxxxxxxxxxxx'
'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
0 => 'xxxxxxxxxxxxxxxxxxxxxxx.xxx'
'datadirectory' => '/media/Nextcloud/data'
'version' => '15.0.2.0',
'overwrite.cli.url' => 'xxxxxxxxxxxxxxxxxxxx.xxx'
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'xxxxxxxxxx',
'dbpassword' => 'xxxxxxxxxxxxxxxxxx',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'mail_smtpport' => '465',
'mail_smtphost' => 'xxxxxxxxxxxxxxxx',
'mail_domain' => 'xxxxxxxxxxxx',
'mail_from_address' => 'xxxxxxxxxxxxxxxx',
'mail_smtpname' => 'xxxxxxxxxxxxxxxxx',
'mail_smtppassword' => 'xxxxxxxxxxxxxxxxxxxxxxx',
'theme' => '',
'loglevel' => 2,
'updater.secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
