Originally published at: May maintenance updates are here: Nextcloud Hub 9 and 10 - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 8, 9 or 10, we strongly recommend you to update to version 30.0.11 or 31.0.5 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
The updates include a number of important bug fixes and improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
- Nextcloud Hub 9 (version 30.0.11)
- Nextcloud Hub 10 (version 31.0.5)
Nextcloud Hub 10: your unified, modular digital workspace 🚀
Welcome Nextcloud Hub 10 – our most integrated, modular platform for secure collaboration. Our latest release comes with reinforced performance in every app, deeper integration across the platform, and dozens of new features that will make your day easier:
- End-to-End encryption in calls and web
- Performance improvements across all our products
- Thousands of tweaks for improved UX and stability
- Nextcloud Assistant 3.0 – your new personal assistant
- File conversion directly in Nextcloud Files
- Smarter team sharing with Team folders
- Schedule meetings directly in Nextcloud Talk
- Mail you love again: translations, summaries, and mentions
- … and much more!
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
