example
longer
example
here
Nextcloud version (eg, 12.0.2): Nextcloud 18.0.3
Operating system and version (eg, Ubuntu 17.04): Linux Mint Tessa (equivalent to Ubuntu 18.0.4)
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.14.0
PHP version (eg, 7.1): 7.3.16
My Nextcloud instance doesn’t correctly show me the correct max quota for my own account (that also happens to be the admin account). If I set the max quota through occ, the max storage is shown correctly (username and email redacted):
However, if I look anywhere else, this max quota doesn’t change in the files app and the settings:
Files:
Settings:
This happened to me in Nextcloud version 17.0.4. An upgrade to 18.0.3 didn’t fix this problem, which I kind of expected…
Is this the first time you’ve seen this error? (Y/N): No.
- Use occ command to change admin’s max storage quota (sudo -u www-data php occ user:setting files quota )
- Go to Users page and see that max quota was set in user settings
- Go to either the files app or the settings and see that the max quota is locked at 2.7 TB (in my case)
https://pastebin.com/GhcFVw5e
https://pastebin.com/XWySyEWX
Access Log: https://pastebin.com/zBXcYeNw
Error Log: https://pastebin.com/VWyZRY5V
