Markdown linting/formatting in Nextcloud: Is there already a built-in or community solution?
I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
Hi everyone,
quick question:
We use Nextcloud for technical documentation and work with many Markdown files.
Is there already a way to lint Markdown in Nextcloud (similar to markdownlint)?
Or is there already a way to auto-format Markdown in Nextcloud (similar to Prettier)?
Are there existing apps/plugins/integrations for this?
If yes, how is it set up in practice?
Thanks in advance for any pointers.
