New RCs are out!
31.0.1RC1, 30.0.7RC and 29.0.13RC1
As always, your help testing those releases is much appreciated!
Please report an issues you may find on our github repositories.
Downloads:
- https://download.nextcloud.com/server/prereleases/nextcloud-31.0.1rc1.zip
- https://download.nextcloud.com/server/prereleases/nextcloud-30.0.7rc1.zip
- https://download.nextcloud.com/server/prereleases/nextcloud-29.0.13rc1.zip
Changelogs
v31.0.1rc1
- Chore: bump @nextcloud/cypress from 1.0.0-beta.8 to 1.0.0-beta.14 (activity#1890)
- Chore(deps): bump webdav from 5.7.1 to 5.8.0 (server#51186)
- Chore(deps): update
@nextcloud/uploadto 1.9.0 (server#51262) - Ci(autochecks): Run some autochecks also on non-PHP files (server#50953)
- Ci(performance): Fix performance test and ease debugging it (notifications#2228)
- Feat: Add bases and gidNumber attribute to ldap:test-user-settings output (server#51227)
- Feat: Close sessions created for login flow v2 (server#51090)
- Feat: log query for dbal exceptions (server#51230)
- Feat: Support deleting metadata from WebDAV (server#51223)
- Feat: support migrating an instance to sharding (server#51034)
- Feat(files): allow to ignore warning to change file type (server#51015)
- Files: fix exception when share-attributes is undefined (server#51093)
- Fix A+ rating when checking with Nextcloud Security Scan. (server#51173)
- Fix parameter preparation for occ command (app_api#525)
- Fix SQL query so that it is ansi safe fixing #51067 (server#51091)
- Fix: Change UserAgent to *cloud (server#50941)
- Fix: Correct alignment of recommendation text (recommendations#854)
- Fix: Initialize lastConnectionCheck after first connection (server#51017)
- Fix: NotFoundException for anonymous users (server#51003)
- Fix: Pin pdfjs-dist to exact 4.0.189 (files_pdfviewer#1165)
- Fix: remove caching in fetchListOfGroups (server#51111)
- Fix: Report duplicated extra files in integrity check (server#51062)
- Fix: Use case insensitive check when validating login name (server#51251)
- Fix: wipe local storages on log out (server#50995)
- Fix(admin_audit): Fix incorrect truncation of files path in admin audit log (server#50994)
- Fix(Comment): replace richEditor mixin with NcRichText (server#51268)
- Fix(cron): Ignore time sensitivity when a class was explicitely scheduled (server#50954)
- Fix(cypress): wait for toast to appear (server#51143)
- Fix(dav): Handle end of stream in
File::put(server#51128) - Fix(dav): Handle long absence status earlier (server#51273)
- Fix(dav): Use IUser::getDisplayName directly (server#51283)
- Fix(FederatedShareProvider): Delete external shares when groups are deleted or users removed from a group (server#51206)
- Fix(files_external): Move definition parameter to the correct place (server#51106)
- Fix(files_external): request strict password auth on credentials enter action (server#50932)
- Fix(files_reminders): Do not attempt to send reminders after a user has left a share (server#51121)
- Fix(files_sharing): ensure downloaded file has the correct filename (server#51263)
- Fix(files_sharing): ignore duplicated navigation when replacing current route (server#51236)
- Fix(files_sharing): Map sharee information for
shared-by-youview (server#50935) - Fix(files_trashbin): disable bulk download for trashbin (server#51210)
- Fix(files_versions): Do not expire versions newer than min age (server#51025)
- Fix(files): Donāt do session related work in the constructor of the View (server#51276)
- Fix(files): Ensure the filter instance is mounted (server#51132)
- Fix(l10n): Improve english source strings (server#51058)
- Fix(l10n): Remove leading space from translation string (server#51289)
- Fix(login): Properly target public page with attribute (server#51295)
- Fix(lookup_server_connector): correctly handle account properties (server#51237)
- Fix(occ): handle share wrappers that do not have a circle (circles#1867)
- Fix(push): Check last activity and last check for age (notifications#2240)
- Fix(push): Improve test-push output (notifications#2242)
- Fix(systemtags): unify restrict_creation_to_admin handling (server#51308)
- Fix(systemtags): Use literal strings for i18n in showSuccess (server#51047)
- Fix(translation): Fix string concatenation in LDAP endpoint (server#51076)
- Fix(userconfig): simpler db request pre-upgrade (server#51197)
- Fix/6871 smart add to next line (text#6916)
- Get PDF.js version from āpackage-lock.jsonā (files_pdfviewer#1162)
- Make it possible to run occ as root (server#51118)
- Refactor(TempManager): Simplify and unify implementations and remove legacy behavior (server#51203)
- Remove space (server#51149)
- Spelling standardization (server#51028)
- Test(e2e): adjust trashbin tests to be less flaky (server#51257)
v30.0.7rc1
- Add LDAP test settings command (server#50691)
- Bug/48678/restore dav error response (server#49481)
- Catch undef recipient (circles#1804)
- Chore: Update composer files (text#6884)
- Chore(deps): bump webdav from 5.7.1 to 5.8.0 (server#51187)
@nextcloud/uploadto 1.9.0 (server#51261) - Ci(autochecks): Run some autochecks also on non-PHP files (server#50952)
- Ci(performance): Fix performance test and ease debugging it (notifications#2227)
- Enh(makefile): clean up css as well (text#6921)
- Feat: Close sessions created for login flow v2 (server#51089)
- Feat: log query for dbal exceptions (server#51231)
- Feat: Support deleting metadata from WebDAV (server#51222)
- Feat(push): Show error when internet connection is disabled in configuration (notifications#2193)
- Fix incorrect permissions when copying shared files (server#49657)
- Fix: Change UserAgent to *cloud (server#50940)
- Fix: donāt use cached root info from shared cache if the watcher has detected an update (server#50761)
- Fix: fix docs URL in info.xml (activity#1885)
- Fix: Fix regression in calendar invitation sending (server#50803)
- Fix: Initialize lastConnectionCheck after first connection (server#51016)
- Fix: Load focus trap extension in markdown content editor (text#6854)
- Fix: Make āshare onā entries same width (firstrunwizard#1341)
- Fix: make sure we process mime extensions as string (server#50704)
- Fix: NotFoundException for anonymous users (server#51002)
- Fix: Pin pdfjs-dist to exact 4.0.189 (files_pdfviewer#1166)
- Fix: Report duplicated extra files in integrity check (server#51061)
- Fix: style and template fixes (notifications#2223)
- Fix: Usage of FilePicker (photos#2801)
- Fix: Use case insensitive check when validating login name (server#51252)
- Fix: validate account properties as a repair step (server#51004)
- Fix: wipe local storages on log out (server#50997)
- Fix(activity): Fix activity parameter types (server#50862)
- Fix(cron): Keep job class limitation when searching for the next job (server#50900)
- Fix(cypress): opendetails tests (server#50945)
File::put(server#51127) - Fix(dav): Handle long absence status earlier (server#51272)
- Fix(dav): Use IUser::getDisplayName directly (server#51282)
- Fix(FederatedShareProvider): Delete external shares when groups are deleted or users removed from a group (server#51205)
- Fix(files_external): Move definition parameter to the correct place (server#51105)
- Fix(files_external): request strict password auth on credentials enter action (server#50931)
- Fix(files_sharing): Also list deleted team shares (server#50925)
- Fix(files_sharing): Fix public share expiration being set when toggle is not enabled (server#50891)
shared-by-youview (server#50934) - Fix(files_trashbin): disable bulk download for trashbin (server#51209)
- Fix(files_versions): Do not expire versions newer than min age (server#51024)
- Fix(files): add
tiptap-text-directionextension to support RTL (text#6904) - Fix(files): Correctly copy the cache information during copy operations (server#50804)
- Fix(files): Do not download files with openfile query flag (server#50706)
- Fix(files): Donāt do session related work in the constructor of the View (server#51277)
- Fix(files): handle failed node properly (server#50947)
- Fix(files): properly forward open params from short urls (server#50877)
- Fix(files): Properly reset all file list filters on view change (server#50295)
- Fix(l10n): Fix triple dot in translation (server#50948)
- Fix(l10n): Improve english source strings (server#51057)
- Fix(login): only show error state on login box if user interacted (server#50849)
- Fix(login): Properly target public page with attribute (server#51294)
- Fix(lookup_server_connector): correctly handle account properties (server#51238)
- Fix(occ): handle share wrappers that do not have a circle (circles#1868)
- Fix(push): Check last activity and last check for age (notifications#2239)
- Fix(push): Improve test-push output (notifications#2241)
- Fix(repair): PHP8.3 deprecation warning (server#50837)
- Fix(SharedStorage): Check if storage ID is set on cache (server#50813)
- Fix(systemtags): do not hide if no tags (server#50888)
- Fix(TaskProcessing\Manager): Always use distributed cache and use PHP serialize (server#50682)
- Fix(test): Add missing data-cy attribute for file actions (server#51281)
- Fix(transferownership): Allow searching new owner by email (server#50853)
- Fix(translation): Fix string concatenation in LDAP endpoint (server#51285)
- Fix(user_ldap): Avoid extra LDAP request when mapping a user for the first time (server#50778)
- Get PDF.js version from āpackage-lock.jsonā (files_pdfviewer#1161)
- Improve error logging (app_api#514)
- Lighter api to get circles (circles#1879)
- Lighter link to memberships (circles#1884)
- Make it possible to run occ as root (server#51119)
- Perf(files): faster query to fetch incomplete directories (server#50796)
- Refactor(TempManager): Simplify and unify implementations and remove legacy behavior (server#51202)
- Remove space (server#51150)
- Revert āRevert āfix: Handle copy of folders containing live photosāā (server#49840)
- Share must be linked to an existing circle (circles#1807)
- Test: re-add object store primary storage phpunit tests (server#49802)
- Update
@nextcloud/vueto v8.23.1 (server#50914)
v29.0.13rc1
- Bug/48678/restore dav error response (server#49483)
- Chore: Update composer files (text#6885)
@nextcloud/uploadto 1.9.0 (server#51260) - Ci(autochecks): Run some autochecks also on non-PHP files (server#50951)
- Feat: Close sessions created for login flow v2 (server#51088)
- Feat(push): Show error when internet connection is disabled in configuration (notifications#2192)
- Fix: Change UserAgent to *cloud (server#50939)
- Fix: Initialize lastConnectionCheck after first connection (server#51018)
- Fix: make sure we process mime extensions as string (server#50703)
- Fix: NotFoundException for anonymous users (server#51001)
- Fix: Pin pdfjs-dist to exact 4.0.189 (files_pdfviewer#1167)
- Fix: Report duplicated extra files in integrity check (server#51060)
- Fix: Use case insensitive check when validating login name (server#51253)
- Fix: validate account properties as a repair step (server#51006)
- Fix: wipe local storages on log out (server#50996)
- Fix(dav): Handle long absence status earlier (server#51271)
- Fix(FederatedShareProvider): Delete external shares when groups are deleted or users removed from a group (server#51204)
- Fix(files_external): Move definition parameter to the correct place (server#51104)
- Fix(files_external): request strict password auth on credentials enter action (server#50930)
- Fix(files_sharing): Also list deleted team shares (server#50924)
- Fix(files_sharing): Fix public share expiration being set when toggle is not enabled (server#50890)
- Fix(files_versions): Do not expire versions newer than min age (server#51023)
- Fix(files): Correctly copy the cache information during copy operations (server#50805)
openfilequery flag (server#50815) - Fix(files): Donāt do session related work in the constructor of the View (server#51278)
- Fix(files): properly forward open params from short urls (server#50876)
- Fix(l10n): Improve english source strings (server#51068)
- Fix(login): only show error state on login box if user interacted (server#50848)
- Fix(login): Properly target public page with attribute (server#51293)
- Fix(Mailer): Fix sendmail binary fallback (server#48108)
- Fix(occ): handle share wrappers that do not have a circle (circles#1869)
- Fix(push): Check last activity and last check for age (notifications#2238)
- Fix(repair): PHP8.3 deprecation warning (server#50836)
- Fix(SharedStorage): Check if storage ID is set on cache (server#50810)
- Fix(systemtags): do not hide if no tags (server#50887)
- Fix(test): Add missing data-cy attribute for file actions (server#51284)
- Fix(transferownership): Allow searching new owner by email (server#50856)
- Fix(translation): Fix string concatenation in LDAP endpoint (server#51286)
- Get PDF.js version from āpackage-lock.jsonā (files_pdfviewer#1160)
- Lighter api to get circles (circles#1878)
- Lighter link to memberships (circles#1883)
- Perf(files): faster query to fetch incomplete directories (server#50795)
- Refactor(TempManager): Simplify and unify implementations and remove legacy behavior (server#51201)
