Nextcloud version (eg, 15.0.2): 15.0.7 to 16.0.11
Operating system and version (eg, Ubuntu 20.04):
PHP version (eg, 7.1): 7.2.34
Trying to upgrade to 16.0.11, using the manual upgrade instructions. I’m getting
Is this the first time you’ve seen this error? (Y/N): yes.
Unzip the new version, copy my config.php over. I’m moving to using an external data directory so I copied my data to that external directory
~/nextcloud/data/
and confirmed that the permissions are the same. Updateconfig.php
to use the new directory. Copy any missing app directories from my oldapps
directory to the new one. -
run the following commands:
php occ maintenance:mode --on
php occ upgrade -
Error!
UnexpectedValueException: The files of the app "gallery" were not correctly replaced before running the update Update failed
Tried running:
php occ integrity:check-core
php occ maintenance:repair
but I’m still getting the same error.
'instanceid' => 'occ7c1677a99',
'passwordsalt' => 'c8c4055cd1ab30f17585f25e64a987',
0 => 'velociraptor.info',
1 => 'www.velociraptor.info',
'datadirectory' => '/home/REDACTED/nextcloud/data',
'overwrite.cli.url' => 'https://REDACTED.info/nextcloud',
'dbtype' => 'sqlite3',
'version' => '15.0.7.0',
'theme' => '',
'maintenance' => true,
'secret' => 'be61750202d8bf05cd0ebbd83a4557d098a048bf2a153062d0fe07b973e1a805ac29e374e20855388d7ce2843826b132',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => 'REDACTED+nextcloud',
'mail_domain' => 'REDACTED.info',
'mail_smtpauthtype' => 'PLAIN',
'mail_smtphost' => 'mail.REDACTED.info',
'mail_smtpauth' => 1,
'mail_smtpport' => '587',
'mail_smtpname' => 'REDACTED',
'mail_smtppassword' => 'REDACTED',
'loglevel' => 2,
'trashbin_retention_obligation' => 'auto',
'defaultapp' => 'calendar',
'session_lifetime' => 86400,
'updater.secret' => '$2y$10$y2oK6kXqYAAkbV64sV5Jiu1NimzLjJyYmTwpg/pvgx1V83Cya2vFe',
