Major issue with potential data loss
    • Nextcloud Hub 9 (30.0.4)
    • Client: Pop!_OS 22.04 LTS
    • Server: Ubuntu 22.04.4 LTS
    • Apache through AIO
    • replace me
    • replace me
    • Yes
    • 18 December 2024 @1426UTC
    • AIO
Possible data loss. When I now try to access the Personal Board (Deck) I get a screen saying I need to create a List (I had four lists before the error started) and a warning similar to this: ``
There are errors in the log shown below.
This started when I was entering a new card on my Personal board in my Backlog List, and tried to add a due date (which I typically do not use). The autosave feature kept kicking me out of the date field while trying to enter month, year and date, so I switched to the date picker. Something went haywire, then the card showed invalid date. I couldn’t change it, so I created a new card, and just used the date picker. But then I couldn’t delete the “invalid” card, and on screen refresh I got the notice described above.
These are the steps that led to the issue. I’ve not tried replicating because my first concern is to recover my data (I do have a backup I can restore if necessary):
  1. Selected Personal Board
  2. In Backlog list, clicked icon to “Create Card”
  3. Entered name of card, then accepted
  4. Opened details of card
  5. Clicked + symbol to add due date
  6. Started typing date 03/15 etc. As autosave keeps kicking me out of the field I’m typing (a different issuee) I switched to the date selector.
  7. Tried to select correct due date and time
  8. Saved card, but found it showed data as invalid. Edited a couple of times but still it showed an invalid data.
  9. Created new card and used date picker to selected due date. Saved card.
  10. Tried to delete card showing the invalid date. I couldn’t delete the offending card.
  11. Refreshed screen, and got the screen showing above in the screen cap.
The Paste Bin contains the first entry in the log. This basic error is repeated dozens of times, showing for both Deck and Core applications.
https://pastebin.com/NnvNrmuc
docker logs nextcloud-aio-database
2024-12-18 14:35:49.692 UTC [16298] ERROR:  duplicate key value violates unique constraint "oc_text_documents_pkey"
2024-12-18 14:35:49.692 UTC [16298] DETAIL:  Key (id)=(10077) already exists.
2024-12-18 14:35:49.692 UTC [16298] STATEMENT:  INSERT INTO "oc_text_documents" ("id", "last_saved_version_time", "last_saved_version_etag", "base_version_etag") VALUES($1, $2, $3, $4)
PASTE
PASTE HERE
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "appsallowlist": false,
        "redis": {
            "port": 6379
        "overwritehost": "***REMOVED",
        "overwriteprotocol": "https",
            "localhost",
            "***REMOVED***"
        "dbtype": "pgsql",
        "version": "30.0.4.1",
        "overwrite.cli.url": "https:\/\/***REMOVED***\/",
        "dbport": "",
        "loglevel": "2",
        "log_type": "file",
        "log_rotate_size": "10485760",
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": "2048",
        "preview_max_y": "2048",
        "jpeg_quality": "60",
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": "30",
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": 1,
        "mail_smtpport": "587",
        "default_phone_region": "US",
        "DOMAIN": "***REMOVED***"
  - activity: 3.0.0
  - admin_audit: 1.20.0
  - app_api: 4.0.3
  - bruteforcesettings: 3.0.0
  - calendar: 5.0.7
  - circles: 30.0.0
  - comments: 1.20.1
  - contacts: 6.1.1
  - contactsinteraction: 1.11.0
  - dashboard: 7.10.0
  - dav: 1.31.1
  - deck: 1.14.2
  - federation: 1.20.0
  - files: 2.2.0
  - files_downloadlimit: 3.0.0
  - files_fulltextsearch: 30.0.0
  - files_pdfviewer: 3.0.0
  - files_reminders: 1.3.0
  - files_sharing: 1.22.0
  - files_trashbin: 1.20.1
  - files_versions: 1.23.0
  - firstrunwizard: 3.0.0
  - fulltextsearch: 30.0.0
  - fulltextsearch_elasticsearch: 30.0.0
  - logreader: 3.0.0
  - maps: 1.5.0
  - nextcloud-aio: 0.7.0
  - notes: 4.11.0
  - notifications: 3.0.0
  - notify_push: 0.7.0
  - oauth2: 1.18.1
  - password_policy: 2.0.0
  - photos: 3.0.2
  - privacy: 2.0.0
  - provisioning_api: 1.20.0
  - recommendations: 3.0.0
  - related_resources: 1.5.0
  - richdocuments: 8.5.3
  - serverinfo: 2.0.0
  - settings: 1.13.0
  - sharebymail: 1.20.0
  - support: 2.0.0
  - survey_client: 2.0.0
  - systemtags: 1.20.0
  - tasks: 0.16.1
  - text: 4.1.0
  - theming: 2.5.0
  - twofactor_totp: 12.0.0-dev
  - user_status: 1.10.0
  - viewer: 3.0.0
  - weather_status: 1.10.0
  - workflowengine: 2.12.0
  - encryption: 2.18.0
  - files_external: 1.22.0
  - files_rightclick: 0.15.1 (installed 1.6.0)
  - suspicious_login: 8.0.0
  - user_ldap: 1.21.0
The error states a lot of information actually, would you be familiar to databases. Entries (rows) in database tables have their own identifier, an ID, similar to names for people. Sometimes, errors occur, as in your case, when an identical combination is found. Regard it as the unique identification of a person being the combination of initials. In your case, the error is provided that the system tries to write an entry for your deck, however it finds that there is already such an entry.
What I would do, given that I have experience with databases, is trying to erase the current row in the database for the same ID, so the process can finish writing the old entry.
However, in my experience most plugins have their own data registered, so I would not be concerned about the files on the system. If you would, please make a backup of the data directory, please use recursiveness (I had one of my first backups only populated with the few files in the main directory and a list of empty directories.)
I do have some familiarity with databases, and will try to find the offending entry to delete it. You’re thinking this will “recover” the rest of the entries in Deck?
I realize the lack of data shown on the screen for that board might simply be because the data can’t be loaded. If this is the case, I’d suggest the error message isn’t helpful.
Assuming I am able to restore things to prior to the crash, then the question will become what caused the duplicate key, and is that related to the date picker issue that started all of this?
In looking at the database dump, it is clear I do not have enough knowledge of how NextCloud data is structured or sql databases.
If you have a suggested query to find the duplicate ID, I’d be happy to try it.
Thanks.
