I have upgraded my nextcloud from version 12.0.0 to 12.0.1 today, because the updater said an update is available. So I did click on that button and it installed. When I wanted to access my cloud, the maintenance mode was still activated. (I choosed to deactivate it after the upgrade) I ran an occ command to repair my cloud because something is wrong. (occ maintenance:repair) and this command threw some weird errors. Because I need my files I just deactivated the maintenance mode and it seems to work. But I fear that something will break if I have these errors around. Can someone explain what these errors are and how to fix them?
Nextcloud version: 12.0.1
Operating system and version: Ubuntu 16.04
Apache or nginx version: Apache 2.4.18 (Ubuntu)
PHP version v7.0.22-0ubuntu0.16.04.1
Is this the first time you’ve seen this error?: Yes
Can you reliably replicate it? (If so, please outline steps):
Upgrade from 12.0.0 to 12.0.1 with the web updater
Here is the output of my terminal:
root@nextcloud:/var/www/html/nextcloud# sudo -u www-data php /var/www/html/nextcloud/occ maintenance:repair
Nextcloud is in maintenance mode - no app have been loaded
Failed to load repair step for circles: Repair step 'OCA\Circles\Migration\UpdateShareTimeToTimestamp' is unknown
Failed to load repair step for circles: Repair step 'OCA\Circles\Migration\ImportOwncloudCustomGroups' is unknown
Failed to load repair step for circles: Repair step 'OCA\Circles\Migration\GenerateUniqueIdOnCreatedCircle' is unknown
Failed to load repair step for circles: Repair step 'OCA\Circles\Migration\UsingShortenUniqueIdInsteadOfCircleId' is unknown
Failed to load repair step for dav: Repair step 'OCA\DAV\Migration\FixBirthdayCalendarComponent' is unknown
Failed to load repair step for dav: Repair step 'OCA\DAV\Migration\CalDAVRemoveEmptyValue' is unknown
Failed to load repair step for dav: Repair step 'OCA\DAV\Migration\BuildCalendarSearchIndex' is unknown
Failed to load repair step for deck: Repair step 'OCA\Deck\Migration\UnknownUsers' is unknown
Failed to load repair step for files_sharing: Repair step 'OCA\Files_Sharing\Migration\OwncloudGuestShareType' is unknown
Failed to load repair step for files_sharing: Repair step 'OCA\Files_Sharing\Migration\SetPasswordColumn' is unknown
Failed to load repair step for mail: Repair step 'OCA\Mail\Migration\FixCollectedAddresses' is unknown
Failed to load repair step for ocsms: Autoload path not allowed: /var/www/html/nextcloud/apps/ocsms/lib/migration/fixconversationreadstates.php
Failed to load repair step for theming: Repair step 'OCA\Theming\Migration\ThemingImages' is unknown
Failed to load repair step for twofactor_backupcodes: Repair step 'OCA\TwoFactorBackupCodes\Migration\CopyEntriesFromOldTable' is unknown
- Repair MySQL collation
- All tables already have the correct collation -> nothing to do
- Repair mime types
- Clean tags and favorites
- 0 tags of deleted users have been removed.
- 0 tags for delete files have been removed.
- 0 tag entries for deleted tags have been removed.
- 0 tags with no entries have been removed.
- Repair invalid shares
- Remove shares of a users root folder
- Move .step file of updater to backup location
- Add move avatar background job
- Repair step already executed
- Add preview cleanup background jobs
- Fix potential broken mount points
- No mounts updated
- Repair language codes
- Install new core bundle components
- Repair invalid paths in file cache
