Hello Folks,
when I run “occ maintenance:mode --on” it takes roughly 30 seconds until the maintenance mode is active, same for turning it off. I tried creating a file in this time and it was beeing created. Is this a normal (aka expected) behavior? When updating an app the maintenance mode start immediately.
I want to use the maintenance mode while triggering a backup, since I use ZFS a backup doesn’t take a lot of time, but I’d like to make sure that nextcloud is in a safe state. On the same time I want to reduce downtime, so I thought instead of stopping the container I could just put it into maintenance mode and then put it out of maintenance mode again. However, restarting the container seems faster at the moment.
Nextcloud version: 26.0.4
Operating system and version: official docker container (production) on unraid host
Any ideas if I’m doing something wrong or if there is some kind of config I might be doing wrong?
Thank you in advance
Autchi
