Anmelden geht wie immer. Die nextcloud.log enthÀlt nur den gleichen Eintrag immer wieder:
{"reqId":"W1t6SsPKwQ4hqnk9dnbX","level":3,"time":"2023-01-20T12:19:33+01:00","remoteAddr":")(entfernt)","user":"nc_admin","app":"PHP","method":"PROPFIND","url":"/remote.php/dav/files/nc_admin/","message":"disk_free_space(): No such file or directory at /var/www/nextcloud/lib/private/Files/Storage/Local.php#420","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/109.0","version":"25.0.3.2","exception":{"Exception":"Error","Message":"disk_free_space(): No such file or directory at /var/www/nextcloud/lib/private/Files/Storage/Local.php#420","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Local.php","line":420,"function":"disk_free_space"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Quota.php","line":110,"function":"free_space","class":"OC\\Files\\Storage\\Local","type":"->"},{"file":"/var/www/nextcloud/lib/private/legacy/OC_Helper.php","line":521,"function":"free_space","class":"OC\\Files\\Storage\\Wrapper\\Quota","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","line":328,"function":"getStorageInfo","class":"OC_Helper","type":"::"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":770,"function":"getQuotaInfo","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/PropFind.php","line":95,"function":"Sabre\\DAV\\{closure}","class":"Sabre\\DAV\\CorePlugin","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":774,"function":"handle","class":"Sabre\\DAV\\PropFind","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"propFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1052,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":984,"function":"getPropertiesByNode","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1662,"function":"getPropertiesIteratorForPath","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":1647,"function":"writeMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":346,"function":"generateMultiStatus","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpPropFind","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":360,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":171,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}`
Das Loglevel hat ein Àhnliches Problem wie der maintenance mode - es lÀsst sich zwar in der config Àndern, wird aber nicht angewendet (es bleibt bei der Meldung oben, also loglevel 3):
root@cloud:/home/nca# sudo -u www-data php /var/www/nextcloud/occ log:manage
Enabled logging backend: file
Log level: Warning (2)
Log timezone: Europe/Berlin
root@cloud:/home/nca# sudo -u www-data php /var/www/nextcloud/occ log:manage --level 0
Log level: Debug (0)
root@cloud:/home/nca# grep "log" /var/www/nextcloud/config/config.php
'cron_log' => true,
'log_rotate_size' => '104857600',
'loglevel' => '0',
(reboot)
'cron_log' => true,
'loglevel' => '0',
Ich glaube dass ist jetzt wirklich der Moment zum Aufgeben.
Ich probiere es noch mal mit Debian, danke fĂŒr den Tipp!
