"Maintenance Mode" issue
we have an issue with NextCloud.
I don’t know which version of NextCloud is installed on our server.
I use a VPS server installed on an OVH server.
Our solution was working fine since more than 3 years and for a reason i don’t understand the main page of our NextCLoud solution give us the information that the server is in “maintenance mode”.
I’ve try to restard the server in rescue mode and after that i try this:
but i don’t find the folder where NextCLoud is installed on our server.
Can someone help us restablishing our NextCloud server ?
Thanks ins advance,
Davy
Who installed Nextcloud on this server? We can only guess. It’s often in /var/www somewhere, but the location is ultimately up to the person that installed it.
You can likely find it by determining what web server you’re running on that server and then reviewing the web server configuration to see what sites are configured.
Once you find where Nextcloud is, you’ll be able to find the logs within the configured data directory.
find / -type f -name "occ" -exec dirname {} \; | grep -v "updater"
or
find / -type d -name "ocs" -exec dirname {} \; | grep -v "updater"
and for the data folder:
find / -type f -name ".ocdata" -exec dirname {} \;
