Maintenance mode despite "...mode already disabled"
Hi guys
[/details]
Nextcloud version: [installed] => 1
[maintenance] =>
[needsDbUpgrade] =>
[version] => 15.0.7.0
[versionstring] => 15.0.7
Operating system and version: Debian GNU/Linux 9
Apache or nginx version _: Apache/2.4.25
PHP version : 7.3
I think I accidently switched off an important app and now my nextcloud is in maintenance mode … sort of. Because when I try to disable it via
sudo -u www-data php occ maintenance:mode --off
I get
“Maintenance mode already disabled”
But I still can’t procede. Using a browser it stills shows
“Maintenance mode
This Nextcloud instance is currently in maintenance mode, which may take a while. This page will refresh itself when the instance is available again.
Contact your system administrator if this message persists or appeared unexpectedly.”
It’s also very interesting that status-php gives me this … no information on maintenance on or off
none
  'passwordsalt' => '****',
  'secret' => '*****',
    0 => 'localhost',
  'version' => '15.0.7.0',
  'overwrite.cli.url' => 'http://localhost',
  'dbname' => 'nextclouddb',
  'dbhost' => 'localhost',
  'dbuser' => 'oc_admin3',
  'dbpassword' => '****',
  'instanceid' => 'ocenp6d0r39s',
46.5.44.39 - magmdot [12/Apr/2020:06:46:20 +0000] “PROPFIND /remote.php/dav/files/magmdot/ HTTP/1.1” 503 816 “-” “Mozilla/5.0 (Windows) mirall/2.6.4stable-Win64 (build 20200303) (Nextcloud)”
Thank you!
Hello, I’m in the same situation :
  • maintenance => false in config.php
  • php occ maintenance:mode --off give me the message maintenance mode is already disabled.
    And the web page same me that i’m in maintenance mode.
    I realy don’t know what to do.
    Thanks for helping.
For me it just took a few minutes. Then the maintenance mode was off. I guess it’s cached for a few minutes internally.
