I just installed nextcloud on my whatbox slot. It works fine. I can connect from my ios app and from the webui with no issues.
But when it comes to the desktop app⊠I put my adress âhttps://nextcloud.[âŠ].box.ca/nextcloudâ It goes on the site so i can validate the connection and then i accept. The app add the account and shows directly "the connection with ⊠is closed ".
I have a reverse proxy on whatbox. The nextcloud server is on 18356 port.
here is my config.php
0 => 'nextcloud.[...].box.ca',
'datadirectory' => '/mnt/mpathn/[...]/files/nextcloud/data',
'dbtype' => 'sqlite3',
'version' => '32.0.6.1',
'overwrite.cli.url' => 'https://nextcloud.[...].box.ca/nextcloud',
'overwritehost' => 'nextcloud.[...].box.ca:443',
'overwritewebroot' => '/nextcloud',
'config_preset' => 1,
'app_install_overwrite' =>
When i click on the adress, the app redirects to :
https://nextcloud.[âŠ].box.ca:18356/nextcloud/
Thatâs why I added âoverwritehostâ => ânextcloud.[âŠ].box.ca:443â,
Has anyone an idea of how i can solve this issue ?
Thanks for your help ! ![]()
