Hello!
I have installed nextcloud in docker recently.
Then I installed all application I needed. Then I restarted docker container (compose down & up -d).
And all application buttons in top-menu (header) got lost.
Is there a file(s) which I could externalize from docker container in order to fix it?
Or is this a common behavior?
And if I try to change URL to access any app installed previously then I get redirected to /apps/dashboard. Seems all apps are not installed after docker docker restarting. But in application list all installed apps is “on”.
