🚀 Looking for Freelancer: Develop a Productivity Control Plugin for Nextcloud
Project Description
We are looking for an experienced Nextcloud plugin developer to create a productivity control solution fully integrated with the Nextcloud ecosystem.
What we need in the plugin:
:white_check_mark: Employee Widget:
  • Employees can start a timer by selecting the task/activity they are working on.
  • Integration with Nextcloud Talk, Deck, and Files to link activities with conversations, tasks, and documents.
  • Option to choose from categories defined by the admin (e.g., “coffee break,” “internal meeting,” “Project X”).
:white_check_mark: Admin Features:
  • Dashboard with productivity metrics per employee.
  • Detailed reports (exportable to PDF/Excel).
  • Realtime tab: live view of what each employee is currently working on.
  • Category management and configuration panel.
This looks like a solid use case for extending Nextcloud in a clean, maintainable way.
The integration points with Talk, Deck, and Files are all feasible, and the reporting/admin tools are possible to design with scalability in mind.
Happy to help plan and build this out.
You can reach out to me on my email here
Colin
Hi, I sent you an email, but I didn’t receive a reply…
