Nextcloud version: Nextcloud Hub 8 (29.0.2)
Operating system and version: Raspbian GNU/Linux 10 (buster)
Apache version: Apache/2.4.59
PHP version: 8.2.20
I have a Raspberry Pi 4 with Nextcloud installed on it via snap. It has been running without issues for a long time, but recently I’ve checked the logs and they are flooded with:
Invalid "upload_max_filesize" setting. Invalid quantity "16G": value is out of range, using overflow result for backwards compatibility at Unknown#0
Example error logs, basically for each request:
{"reqId":"cexispG7Oc99nVBLe5rQ","level":3,"time":"2024-06-24T08:53:41+00:00","remoteAddr":"209.38.136.56","user":"--","app":"PHP","method":"GET","url":"/","message":"Invalid \"upload_max_filesize\" setting. Invalid quantity \"16G\": value is out of range, using overflow result for backwards compatibility at Unknown#0","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/108.0.0.0 Safari/537.36","version":"29.0.2.2","data":{"app":"PHP"}}
{"reqId":"KGPZ3BsP99A4JBNM7ZX3","level":3,"time":"2024-06-24T10:21:24+00:00","remoteAddr":"redacted_ip","user":"redacted_user","app":"PHP","method":"GET","url":"/index.php/204","message":"Invalid \"upload_max_filesize\" setting. Invalid quantity \"16G\": value is out of range, using overflow result for backwards compatibility at Unknown#0","userAgent":"Mozilla/5.0 (Windows) mirall/3.13.0stable-Win64 (build 20240423) (Nextcloud, windows-10.0.19045 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"29.0.2.2","data":{"app":"PHP"}}
Nextcloud snap configures upload_max_filesize
and post_max_size
in:
config/php/php-fpm.d/www.conf:php_value[upload_max_filesize] = 16G
config/php/php-fpm.d/www.conf:php_value[post_max_size] = 16G
And according to phpinfo that I run from within the Nextcloud the values are set successfully to 16G. So I have no clue why these errors are logged. Moreover, these PHP settings are not user configurable in the Nextcloud snap. I have tried to open an issue for it, but it was closed because they only support Ubuntu and they think it’s not a snap issue.
I don’t see how these errors could be a result of using snaps on Raspbian, and I haven’t changed anything in the config lately except for adjusting the PHP memory limit, I’ve tried setting it to -1
, 1024M
and 128M
, but I didn’t see any effect of the errors. Also there aren’t many user configurable PHP options in the Nextcloud snap.
The only recent change that comes to my mind is that I have replaced the Raspberry Pi 4, I used to have a 4GB version, and now I have a 8GB version. (And that’s why I had increased the memory limit.)
I’d appreciate any help understanding why these errors are logged and how to get rid of them.
