Logout entry missing in menu, no way to logout after impersonation
    • 33.0.6
    • Debian 13
    • nginx 1.22.1
    • 8.4.22
    • previous version ? one month ago ?
    • Manual installation
Logout entry missing in menu, no way to logout.
This does not happens always but when it happens even removing cookies and local store does not fix it while reloging using a private session on the very same browser does work.
Note, i am using SAML SSO version 8.1.3.
There is no menu entry to logout.
trying url /logout fails with CSRF check
deleting cookies using debug (F12) allows to reconnect but still no logout menu.
Using private browsing with a brand new login works,
deleting cookies for whole domain within firefox parameters privacy configuration fixes it.
  1. Log with SSO portal as main user with admin rights
  2. Impersonate as another user ( Account / select accoun, impersonate )
  3. There is no way to exit from this new user connexion.
Then any new login won’t have logout, even after discarding cookies or relogin in portal.
PASTE HERE
Firefox 140.13.0esr (64 bits)
PASTE HERE
The output of occ app:list
  - activity: 6.0.0
  - app_api: 33.0.0
  - bruteforcesettings: 6.0.0
  - calendar: 6.5.1
  - calendar_resource_management: 0.12.1
  - circles: 33.0.0
  - cloud_federation_api: 1.17.0
  - comments: 1.23.0
  - contacts: 8.7.4
  - contactsinteraction: 1.14.1
  - dashboard: 7.13.0
  - dav: 1.36.0
  - deck: 1.17.4
  - federatedfilesharing: 1.23.0
  - federation: 1.23.0
  - files: 2.5.0
  - files_downloadlimit: 5.1.0
  - files_external: 1.25.1
  - files_pdfviewer: 6.0.0
  - files_reminders: 1.6.0
  - files_sharing: 1.25.2
  - files_trashbin: 1.23.0
  - files_versions: 1.26.0
  - firstrunwizard: 6.0.0
  - forms: 5.3.4
  - impersonate: 4.0.0
  - logreader: 6.0.0
  - lookup_server_connector: 1.21.0
  - nextcloud_announcements: 5.0.0
  - notifications: 6.0.0
  - notify_push: 1.3.3
  - oauth2: 1.21.0
  - password_policy: 5.0.0
  - photos: 6.0.0
  - polls: 9.1.4
  - privacy: 5.0.0
  - profile: 1.2.0
  - provisioning_api: 1.23.0
  - recommendations: 6.0.0
  - related_resources: 4.0.0
  - richdocuments: 10.2.0
  - richdocumentscode_arm64: 26.4.104
  - serverinfo: 5.0.0
  - settings: 1.16.0
  - sharebymail: 1.23.0
  - spreed: 23.0.7
  - support: 5.0.0
  - survey_client: 5.0.0
  - systemtags: 1.23.0
  - text: 7.0.1
  - theming: 2.8.0
  - twofactor_backupcodes: 1.22.0
  - twofactor_totp: 15.0.0
  - updatenotification: 1.23.0
  - uppush: 2.5.0
  - user_saml: 8.1.3
  - user_status: 1.13.0
  - viewer: 6.0.0
  - weather_status: 1.13.0
  - webhook_listeners: 1.5.0
  - workflow_script: 4.0.1
  - workflowengine: 2.15.0
  - admin_audit: 1.23.0
  - encryption: 2.21.0
  - suspicious_login: 11.0.0
  - twofactor_nextcloud_notification: 7.0.0
  - user_ldap: 1.24.0 (installed 1.21.0)
This is certainly a browser issue.
Deleting cookies using F12 developer mode does not fix it, but deleting cookies using firefox privacy configuration parameters management does actualy fix it.
A github issue in SAML app Logout link not being shown sometimes · Issue #951 · nextcloud/user_saml · GitHub seems to show same behavior.
