I installed nextcloud on aruba hosting. I activated the two-factor authentication. Now when I try to access it does not make me go because he says that the two-factor authentication is enabled but not configured. How can I access and disable two-factor authentication?
Open an SSH shell to your server and disable the app using the occ command line tool.
I solved it by deleting the two-factor authentication string from the config file.
Can you please tell me the name of the string which you deleted from the config file?
