Login Problem Nextcloud 30.0.2
Hello, I can no longer log in as of today.
After entering the F2A code, this message appears:
Internal Server Error
The server could not complete the request.
If this occurs again, please send the technical details below to your server administrator.
Further details can be found in the server log.
Am on the latest version 30.0.2 on Ubunt Linux
What’s the problem with that?
I got a similar problem. For me the remedy was to disable the password app with the “occ app:disable passwords” from the command line. You can have a look at the nextcloud.log file for further analysis if it does not work for you.
Try remove the app and then install it again.
I have no issues with 30.0.2 and I have an active passwords app. Issues like this (similar but not caused byb the Passwords app) has been solved easily by above method.
Bug report: passwords/src/lib/Services/EnvironmentService.php at 6d6fdef9484b2e3ddbec718aee16e657674cf4ce · blizzz/passwords · GitHub
Temporary workaround: (haven’t tested this myself) Login Problem Version 30.0.2 - #8 by ddeutzer
Closing here and reference to the original topic.
