I have problem to login in nextcloud from local also ldap login did’t work.
NC version is 27
This is log
|Error|index|RuntimeException: OpenSSL reported a problem
- /var/www/nextcloud/lib/private/Authentication/Token/PublicKeyTokenProvider.php - line 118:OC\Authentication\Token\PublicKeyTokenProvider->newToken()
- /var/www/nextcloud/lib/private/Authentication/Token/Manager.php - line 70:OC\Authentication\Token\PublicKeyTokenProvider->generateToken(“*** sensiti … *”)
- /var/www/nextcloud/lib/private/User/Session.php - line 686:OC\Authentication\Token\Manager->generateToken(“*** sensiti … *”)
- /var/www/nextcloud/lib/private/Authentication/Login/CreateSessionTokenCommand.php - line 68:OC\User\Session->createSessionToken(“*** sensiti … *”)
- /var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php - line 39:OC\Authentication\Login\CreateSessionTokenCommand->process()
- /var/www/nextcloud/lib/private/Authentication/Login/CompleteLoginCommand.php - line 47:OC\Authentication\Login\ALoginCommand->processNextOrFinishSuccessfully()
- /var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php - line 39:OC\Authentication\Login\CompleteLoginCommand->process()
- /var/www/nextcloud/lib/private/Authentication/Login/LoggedInCheckCommand.php - line 60:OC\Authentication\Login\ALoginCommand->processNextOrFinishSuccessfully()
- /var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php - line 39:OC\Authentication\Login\LoggedInCheckCommand->process()
- /var/www/nextcloud/lib/private/Authentication/Login/EmailLoginCommand.php - line 68:OC\Authentication\Login\ALoginCommand->processNextOrFinishSuccessfully()
- /var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php - line 39:OC\Authentication\Login\EmailLoginCommand->process()
- /var/www/nextcloud/lib/private/Authentication/Login/UidLoginCommand.php - line 53:OC\Authentication\Login\ALoginCommand->processNextOrFinishSuccessfully()
- /var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php - line 39:OC\Authentication\Login\UidLoginCommand->process()
- /var/www/nextcloud/lib/private/Authentication/Login/UserDisabledCheckCommand.php - line 57:OC\Authentication\Login\ALoginCommand->processNextOrFinishSuccessfully()
- /var/www/nextcloud/lib/private/Authentication/Login/ALoginCommand.php - line 39:OC\Authentication\Login\UserDisabledCheckCommand->process()
- /var/www/nextcloud/lib/private/Authentication/Login/PreLoginHookCommand.php - line 52:OC\Authentication\Login\ALoginCommand->processNextOrFinishSuccessfully()
- /var/www/nextcloud/lib/private/Authentication/Login/Chain.php - line 107:OC\Authentication\Login\PreLoginHookCommand->process()
- /var/www/nextcloud/core/Controller/LoginController.php - line 326:OC\Authentication\Login\Chain->process()
- /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 230:OC\Core\Controller\LoginController->tryLogin(“*** sensiti … *”)
- /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 137:OC\AppFramework\Http\Dispatcher->executeController()
- /var/www/nextcloud/lib/private/AppFramework/App.php - line 183:OC\AppFramework\Http\Dispatcher->dispatch()
- /var/www/nextcloud/lib/private/Route/Router.php - line 315:OC\AppFramework\App::main()
- /var/www/nextcloud/lib/base.php - line 1071:OC\Route\Router->match()
- /var/www/nextcloud/index.php - line 36:OC::handleRequest()|
