example
longer
example
here
Nextcloud version (eg, 20.0.5): 20.0.8.1
Operating system and version (eg, Ubuntu 20.04): Shared server
Apache or nginx version (eg, Apache 2.4.25): shared server
PHP version (eg, 7.4): 7.4
I can’t login. What I did: I tried to connect to an ldap service. I entered all the details. After logging out of Nextcloud I wasn’t able to login anymore.
Is this the first time you’ve seen this error? (Y/N): Yes
Can't enter the webinterface. Therefore no logfiles.
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
0 => 'nxt.***.de',
'datadirectory' => '/is/htdocs/wp1056403_CRZ1BLA5TM/www/nxt/data',
'version' => '20.0.8.1',
'overwrite.cli.url' => 'http://nxt.***.de',
'dbname' => '****-nxt',
'dbhost' => 'localhost',
'dbuser' => 'db***-nxt',
'dbpassword' => '****',
'mail_from_address' => '***',
'mail_smtpmode' => 'smtp',
'mail_domain' => '***.de',
'mail_smtphost' => 'wp***.mailout.server-he.de',
'mail_smtpport' => '25',
'mail_smtpauth' => 1,
'mail_smtpname' => 'wp***',
'mail_smtppassword' => '***',
'theme' => '',
'loglevel' => 0,
'app_install_overwrite' =>
0 => 'activitylog',
'auth.bruteforce.protection.enabled' => false,
I can't access the logs as I'm using a shared server.
