i have setup nextcloud locally in ubuntu using snap install nextcloud its working fine, now i want to login using python i have tried some libraries like
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=80): Max retries exceeded with url: /index.php/login/ocs/v1.php/cloud/capabilities (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fb4e263a490>: Failed to establish a new connection: [Errno 111] Connection refused'))
In nc_py_api I did not add possibility to do so, but if there will be strong argumented request for this I can add it in next upcoming version.
As a workaround I can suggest updating capabilities variable, as in most cases it will be updated after login anyway and cached, so reading it manually what will trigger it caching and will not impact performance in any way.
nc = nc_py_api.Nextcloud(
nc_auth_user="admin",
nc_auth_pass="admin",
nextcloud_url="http://stable27.local"
try:
nc.update_server_info()
except nc_py_api.NextcloudException as e:
print(e) # will be 401 in case of Auth error
