example
longer
example
here
Nextcloud version (eg, 20.0.5): 28.0.5
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04.3 LTS
Apache or nginx version (eg, Apache 2.4.25): nginx 1.23.2
PHP version (eg, 7.4): 8.1.2
Logging / Protokollierung is totaly empty, nothing is shown on the web gui
Is this the first time you’ve seen this error? (Y/N): Yes
- log in to the Nextcloud instance as admin
- go to Verwaltungseinstellungen
- click on Protokollierung
NOT POSSIBlE!
PASTE HERE
PASTE HERE
PASTE HERE
There are nextcloud.log and nextcloud.log.1 at /var/log/nextcloud saved. unfortunately I'm not able to copy the errors from putty to the clipboard in full length.
