Hi.
I have a working NextcloudPi and a USB-drive for data. I have a second USB-drive sormatted using webb-gui btrfs for backups. It works to write backups using webb-gui.
When mounting the drive /media/usbdisk/ as local external storage i can see everything but not write files or do anything else, its writeprotected. Says You dont have permission…
How do I make it writeble? I need to make my data larger by using a second data-usb-disk so that is the same problem.
