Im having issue with my external storage, i have a 1TB toshiba hdd and im trying to add it to my nextcloud server but i cant configure it as it is getting detected in as a storage device but when i add it as a external storage it just doesn’t work (operation is blocked by access user).
Would really appreciate your helping hand as it took me a whole day to configure nextcloud
More information ?
Most likely you should create a symbolic link.
ln -s /tudisk /media/tudisk
the tudisco is a directory that must exist.
Also that your 1tb hdd disk must have permissions
www-data:www-data
chown -R www-data:www-data /tudisk
chmod -R 770 /disk
For example, and that will allow the www-data user to write to your disk.
In the external storage you usually see the userland where nextcloud is installed not the host, either docker, or another container.
The /media/data It is inside the container where nextcloud is located
Thanks for you support, the issue was there was not ‘data’ to give permission to ![]()
