Linux distribution packages for the desktop clients - help out!
a ppa for this would be great. i’ve never made a ppa before but failed on compiling my first attempt for the nextcloud client so I will need to fight with this some-more
if someone who has created ppa’s before could set one up that would be fantastic though
I would prefer an official one.
I’ve spent a little bit of time reading over the generic Ubuntu guide for building a deb, though as the client is a little bit of NC and a lot of OC, I’m struggling to understand how I’d successfully follow this guide: http://packaging.ubuntu.com/html/packaging-new-software.html
Should anyone from the dev team fancy helping me to figure out where in the tree I need to be before running the packaging commands then I’m prepared to look into maintaining a PPA via launchpad for Ubuntu.
We don’t really have a packaging expert on board atm… I know there’s the official documentation and I pointed to the deb sources on the open build server earlier - see here. I’m afraid I can’t do anything more :frowning:
That might be enough, I don’t know… but it looks like it’s failing on the rules file when I try to build the deb.
I made a tar from the build_linux dir, and used that as the basis for the deb which may not have been correct. Maybe being able to merge any changes from the NC repo into an OC repo directly would allow me to more closely follow the documentation I find.
I am trying to build it with make before I attempt to build the deb. I am failing there you cann see my errors here http://pastebin.com/UWjP07Ty
I’ve built a deb with successfully, though using checkinstall rather than the official recommended method. @jospoortvliet should I make that available on the forum for the moment while I carry on figuring out the PPA stuff?
sweet! will you submit it to the archive?
It’s not a ā€œproperā€ build, so I don’t think so. Now I have the checkinstall method working I’ll look to getting a deb built using the traditional approach and see how it goes. If I can build a deb perhaps I can an rpm for RHEL, Fedora & CentOS too. Getting ahead of myself though.
Before you submit it, perhaps provide it somewhere that some people can test it in different environments. Especially if you have doubts about the whole procedure.
There’s also this dude - https://morph027.gitlab.io/post/nextcloud-install-via-packages-on-jessie/ perhaps he is interested in helping out.
I’ve had a time getting it to install on Debian 8. I followed the instructions here: Compile instructions from Reddit and got an error with the ā€œcmakeā€¦ā€ part of the steps. I ignored that and proceeded to make and make install. I think that’s basically the same procedure as on the Github instructions. Somewhere between make install and starting it from command line I got an error about libnextcloudsync.so.0, but then I found this lucky tip which fixed that issue. Error while loading shared libraries
So, all that being done I got it to run from the command line! It ran and synced…and then I wanted to close the terminal I had opened so I did…and of course nextcloud quit with the terminal window.
So now I’m trying to set it to run at startup or something and…sheesh, I’m tired!
I love Nextcloud; I mean this is a seriously great endeavour. But compiling this beast on Debian 8 (lxde desktop) for a noob like myself is a daunting proposition!
Keep up the good work, and the better documentation!
https://www.c-rieger.de/how-to-install-nextcloud-desktop-client-for-ubuntu/
This tutorial works perfectly, it’s not so hard to do :wink: Of course, a little sudo apt install nextcloud-client will be awesome :wink:
I’m using docker to build things and keep my system clean. Instructions and CI for xenial is here: https://gitlab.com/packaging/nextcloud-client/
Resulting repo: http://repo.morph027.de/nextcloud-client.php
Please note, that the PPA mentioned below is no longer maintained and will be removed soon.
It is replaced by the PPA named ppa:nextcloud-devs/client. You can start using this PPA by issuing the following commands:
sudo add-apt-repository ppa:nextcloud-devs/client
sudo apt-get update
You can remove the old PPA by:
sudo add-apt-repository -r ppa:ivaradi/nextcloud-client-ppa
I have created a PPA for the Nextcloud client. It currently contains the packages for Ubuntu Trusty, Xenial and Yakkety. Install as follows:
sudo add-apt-repository ppa:ivaradi/nextcloud-client-ppa
sudo apt-get update
sudo apt-get install nextcloud-client
Please, let me know your results, and if it is useful or not.
Thanks very much for setting up this PPA! I’ve just used it to install the Nextcloud client on Ubuntu 16.04 LTS without any problems.
Amazing!
Could you share your methods of packaging the client and pushing to the PPA?
Linux Mint 18 Mate: Installation without problems, sync runs, default system icon in the menu, seems to be useful
Works great on Ubuntu 16.04!
works fine on my Linux Mint 17.3 Cinnamon, Thanks
