Nextcloud version (eg, 12.0.2): 18.0.0
Operating system and version (eg, Ubuntu 17.04): Centos
Apache or nginx version (eg, Apache 2.4.25): DOCKER IMAGE
PHP version (eg, 7.1): DOCKER IMAGE
docker-compose.yml
version: '3'
services:
mysql:
image: mariadb:10.4
restart: unless-stopped
env_file:
- db.env
networks:
- default
volumes:
- "./_data/mysql:/var/lib/mysql"
command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW --log-bin=/var/log/mysql/mariadb-bin
redis:
image: redis:5.0-alpine
networks:
- default
volumes:
- "./_data/redis:/data"
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch:7.3.2
restart: always
environment:
- node.name=es01
- discovery.type=single-node
- "ES_JAVA_OPTS=-Xms512m -Xmx512m"
ulimits:
memlock:
soft: -1
hard: -1
volumes:
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
- ./_data/elasticsearch/data:/usr/share/elasticsearch/data
- ./_data/elasticsearch/plugins:/usr/share/elasticsearch/plugins
networks:
- default
nextcloud:
image: nextcloud:18-apache
depends_on:
- mysql
- redis
env_file:
- db.env
environment:
MYSQL_HOST: mysql
REDIS_HOST: redis
SMTP_HOST: 172.17.0.1
labels:
- "traefik.enable=true"
- "traefik.frontend.rule=Host:data.xx.de,data.xx.com"
- "traefik.frontend.redirect.permanent=true"
- "traefik.frontend.redirect.regex=https://(.*)/.well-known/(card|cal)dav"
- "traefik.frontend.headers.STSSeconds=15552000"
- "traefik.frontend.headers.STSIncludeSubdomains=true"
- "traefik.frontend.headers.STSPreload=true"
- "traefik.http.routers.nextcloud-https.tls=true"
- "traefik.frontend.redirect.replacement=https://$$1/remote.php/dav/"
networks:
- default
- web
volumes:
- "./nextcloud:/var/www/html"
- "/mnt/zraid/data/nc_data:/var/www/html/data"
- "/mnt/zraid/data/Audio:/mnt/Audio"
- "/mnt/zraid/data/YannickLanger:/mnt/YannickLanger"
- "/mnt/zraid/data/ButtonBeFactory:/mnt/ButtonBeFactory"
- "/mnt/zraid/data/SoulFulFactory:/mnt/SoulFulFactory"
- "/mnt/zraid/data/SISKASElement:/mnt/SISKASElement"
- "/mnt/zraid/data/Final_Cut:/mnt/FinalCut"
- "/mnt/zraid/data/Scan:/mnt/Scan"
- /opt/nextcloud/memory-limit.ini:/usr/local/etc/php/conf.d/memory-limit.ini:ro
cron:
depends_on:
- mysql
- redis
volumes:
entrypoint: /cron.sh
# onlyoffice-document-server:
# container_name: onlyoffice-document-server
# image: onlyoffice/documentserver:latest
# stdin_open: true
# tty: true
# restart: always
# labels:
# - "traefik.enable=true"
# - "traefik.frontend.rule=Host:doc.ylfl.de,doc.soulfulfactory.com"
# - "traefik.frontend.redirect.permanent=true"
# - "traefik.frontend.redirect.regex=https://(.*)/.well-known/(card|cal)dav"
# - "traefik.frontend.redirect.replacement=https://$$1/remote.php/dav/"
# volumes:
# - /mnt/zraid/data/onlyoffice/document_data:/var/www/onlyoffice/Data
# - /mnt/zraid/data/onlyoffice/document_log:/var/log/onlyoffice
# networks:
# - default
# - web
networks:
web:
external: true
I added external Files to my Nextcloud Docker Setup and shared links keep dissapearing.
- Add Shared Files as Volume to your Docker-Compose.yml
- Scan all and Share the file
- External users cant Access it and keep getting “A File Not Found Error”
[webdav] Fatal: OCP\Files\NotFoundException: /yannicklanger/files/YannickLanger/03_Noten/05_Git/94.000 Tabs/48000tab/Pop_Rock/Every_Little_Thing at <<closure>>
0. /var/www/html/lib/private/Files/Node/Folder.php line 137
OC\Files\Node\Root->get("/yannicklanger/ ... g")
1. /var/www/html/apps/dav/lib/Connector/Sabre/SharesPlugin.php line 157
OC\Files\Node\Folder->get("/YannickLanger/ ... g")
2. /var/www/html/apps/dav/lib/Connector/Sabre/SharesPlugin.php line 200
OCA\DAV\Connector\Sabre\SharesPlugin->getShares(OCA\DAV\Connector\Sabre\Directory {})
3. /var/www/html/3rdparty/sabre/dav/lib/DAV/PropFind.php line 98
OCA\DAV\Connector\Sabre\SharesPlugin->OCA\DAV\Connector\Sabre\{closure}("*** sensitive parameters replaced ***")
4. /var/www/html/apps/dav/lib/Connector/Sabre/SharesPlugin.php line 207
Sabre\DAV\PropFind->handle("{http://owncloud.org/ns}share-types", Closure {})
5. <<closure>>
OCA\DAV\Connector\Sabre\SharesPlugin->handleGetProperties(Sabre\DAV\PropFind {}, OCA\DAV\Connector\Sabre\Directory {})
6. /var/www/html/3rdparty/sabre/event/lib/EventEmitterTrait.php line 105
call_user_func_array([OCA\DAV\Connect ... "], [Sabre\DAV\PropF ... }])
7. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1059
Sabre\Event\EventEmitter->emit("propFind", [Sabre\DAV\PropF ... }])
8. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 981
Sabre\DAV\Server->getPropertiesByNode(Sabre\DAV\PropFind {}, OCA\DAV\Connector\Sabre\Directory {})
9. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1666
Sabre\DAV\Server->getPropertiesIteratorForPath("files/yannickla ... g", ["{DAV:}resource ... "], 1)
10. /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 355
Sabre\DAV\Server->generateMultiStatus(Generator {}, false)
11. <<closure>>
Sabre\DAV\CorePlugin->httpPropFind(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
12. /var/www/html/3rdparty/sabre/event/lib/EventEmitterTrait.php line 105
call_user_func_array([Sabre\DAV\CorePlugin {},"httpPropFind"], [Sabre\HTTP\Requ ... }])
13. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 479
Sabre\Event\EventEmitter->emit("method:PROPFIND", [Sabre\HTTP\Requ ... }])
14. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 254
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Reque ... "}, Sabre\HTTP\Response {})
15. /var/www/html/apps/dav/lib/Server.php line 319
Sabre\DAV\Server->exec()
16. /var/www/html/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
17. /var/www/html/remote.php line 165
require_once("/var/www/html/a ... p")
PROPFIND /remote.php/dav/files/yannicklanger/YannickLanger/03_Noten/05_Git/94.000%20Tabs/48000tab/Pop_Rock/Every_Little_Thing
from 172.18.0.3 by yannicklanger at 2020-02-14T14:40:17+00:00
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'redis' =>
'host' => 'redis',
'port' => 6379,
'password' => false,
'instanceid' => 'ocmac23wi1t3',
'version' => '18.0.0.10',
'overwrite.cli.url' => 'http://data.xx.com',
'dbname' => 'nextcloud',
'dbhost' => 'mysql',
'dbuser' => 'xx',
'dbpassword' => 'xx',
'passwordsalt' => 'xx',
'secret' => 'xx',
0 => 'data.xx.com',
'theme' => '',
'loglevel' => 2,
'mail_smtpmode' => 'smtp',
'mail_smtphost' => 'xxx',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'no-reply',
'mail_domain' => 'xx.xx',
'mail_smtpauth' => 1,
'mail_smtpport' => '465',
'mail_smtpname' => 'xx',
'mail_smtppassword' => 'xx/xx/xx',
'data-fingerprint' => 'xxx',
'app_install_overwrite' =>
0 => 'contacts',
