Limit download speed
I’m not able to limit the download speed on shared links with nginx.
I added limit_rate 900k; in my server block but I’m still able to download at 60MB/s. I restart nginx of course.
Any solution?
Thanks.
Outside just in a folder this limitation works?
Yes it works outside Nextcloud, I created a test folder and added this config to my server block (below the Nextcloud config) I was limited to 50Kb/s.
location /test/ {
            limit_rate       50k;
Not sure why It’s not working for Nextcloud downloads? Maybe I’m adding it in the wrong location?
Can you post the config?
I added the rule at the end. (Download links contain /download/ in the URL)
upstream php-handler {
    server unix:/run/php/php8.1-fpm.sock;
    #server unix:/var/run/php/php7.4-fpm.sock;
# Set the `immutable` cache control options only for assets with a cache busting `v` argument
map $arg_v $asset_immutable {
    default "immutable";
server {
    listen 80;
    listen [::]:80;
    server_name cloud.mysite.com;
    # Prevent nginx HTTP Server Detection
    server_tokens off;
    # Enforce HTTPS
    return 301 https://$server_name$request_uri;
server {
    listen 443      ssl;
    listen [::]:443 ssl;
    root /home/web/public;
    error_log /home/log/error.log error;
    # Use Mozilla's guidelines for SSL/TLS settings
    # https://mozilla.github.io/server-side-tls/ssl-config-generator/
    ssl_certificate /etc/letsencrypt/live/cloud.mysite.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/cloud.mysite.com/privkey.pem; # managed by Certbot
    server_tokens off;
    # HSTS settings
    # could take several months.
    add_header Strict-Transport-Security "max-age=15768000; includeSubDomains;" always;
    # set max upload size and increase upload timeout:
    client_max_body_size 3072M;
    client_body_timeout 3600s;
    fastcgi_buffers 64 4K;
    gzip on;
    gzip_vary on;
    gzip_comp_level 4;
    gzip_min_length 256;
    gzip_types application/atom+xml text/javascript application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/wasm application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
    # Pagespeed is not supported by Nextcloud, so if your server is built
    # with the `ngx_pagespeed` module, uncomment this line to disable it.
    #pagespeed off;
    # The settings allows you to optimize the HTTP2 bandwitdth.
    # See https://blog.cloudflare.com/delivering-http-2-upload-speed-improvements/
    # for tunning hints
    client_body_buffer_size 512k;
	http2_body_preread_size 1048576;
    # HTTP response headers borrowed from Nextcloud `.htaccess`
    add_header Referrer-Policy                   "no-referrer"       always;
    add_header X-Content-Type-Options            "nosniff"           always;
    add_header X-Download-Options                "noopen"            always;
    add_header X-Frame-Options                   "SAMEORIGIN"        always;
    add_header X-Permitted-Cross-Domain-Policies "none"              always;
    add_header X-Robots-Tag                      "noindex, nofollow" always;
    add_header X-XSS-Protection                  "1; mode=block"     always;
    # Remove X-Powered-By, which is an information leak
    # Add .mjs as a file extension for javascript
    # Either include it in the default mime.types list
    # or include you can include that list explicitly and add the file extension
    # only for Nextcloud like below:
    include mime.types;
    types {
        text/javascript js mjs;
    # Specify how to handle directories -- specifying `/index.php$request_uri`
    # here as the fallback means that Nginx always exhibits the desired behaviour
    # when a client requests a path that corresponds to a directory that exists
    # on the server. In particular, if that directory contains an index.php file,
    # that file is correctly served; if it doesn't, then the request is passed to
    # the front-end controller. This consistent behaviour means that we don't need
    # to specify custom rules for certain paths (e.g. images and other assets,
    # `/updater`, `/ocm-provider`, `/ocs-provider`), and thus
    # `try_files $uri $uri/ /index.php$request_uri`
    # always provides the desired behaviour.
    index index.php index.html /index.php$request_uri;
    # Rule borrowed from `.htaccess` to handle Microsoft DAV clients
    location = / {
        if ( $http_user_agent ~ ^DavClnt ) {
            return 302 /remote.php/webdav/$is_args$args;
    location = /robots.txt {
        allow all;
        log_not_found off;
        access_log off;
    # Make a regex exception for `/.well-known` so that clients can still
    # access it despite the existence of the regex rule
    # `location ~ /(\.|autotest|...)` which would otherwise handle requests
    # for `/.well-known`.
    location ^~ /.well-known {
        # The rules in this block are an adaptation of the rules
        # in `.htaccess` that concern `/.well-known`.
        location = /.well-known/carddav { return 301 /remote.php/dav/; }
        location = /.well-known/caldav  { return 301 /remote.php/dav/; }
        location /.well-known/acme-challenge    { try_files $uri $uri/ =404; }
        location /.well-known/pki-validation    { try_files $uri $uri/ =404; }
        # Let Nextcloud's API for `/.well-known` URIs handle all other
        # requests by passing them to the front-end controller.
        return 301 /index.php$request_uri;
    # Rules borrowed from `.htaccess` to hide certain paths from clients
    location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/)  { return 404; }
    location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console)                { return 404; }
    # Ensure this block, which passes PHP files to the PHP process, is above the blocks
    # which handle static assets (as seen below). If this block is not declared first,
    # then Nginx will encounter an infinite rewriting loop when it prepends `/index.php`
    # to the URI, resulting in a HTTP 500 error response.
    location ~ \.php(?:$|/) {
        # Required for legacy support
        rewrite ^/(?!index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy) /index.php$request_uri;
        set $path_info $fastcgi_path_info;
        include fastcgi_params;
        fastcgi_param PATH_INFO $path_info;
        fastcgi_param HTTPS on;
        fastcgi_param modHeadersAvailable true;         # Avoid sending the security headers twice
        fastcgi_param front_controller_active true;     # Enable pretty urls
        fastcgi_pass php-handler;
        fastcgi_intercept_errors on;
        fastcgi_max_temp_file_size 0;
    # Serve static files
    location ~ \.(?:css|js|mjs|svg|gif|png|jpg|ico|wasm|tflite|map)$ {
        add_header Cache-Control "public, max-age=15778463, $asset_immutable";
        access_log off;     # Optional: Don't log access to assets
        location ~ \.wasm$ {
            default_type application/wasm;
    location ~ \.woff2?$ {
        expires 7d;         # Cache-Control policy borrowed from `.htaccess`
    location /remote {
        return 301 /remote.php$request_uri;
    location / {
        try_files $uri $uri/ /index.php$request_uri;
	if ($bad_referer) {
    return 444; # emtpy response
location /download/ {
    limit_rate 50k;
For me the download links start with:
remote.php/webdav/...
or download and check the logfile for the exact URL (if you have something with /download, there is perhaps a redirect and there it is not limited).
The download link don’t start with /remote.php/ on publicly shared links. Only in the files manager.
I tried with /remote.php/ but NC completely ignore my nginx rule.
Sorry, I missed the part with the shared link. That is for my setup for example:
GET /s/3qHR4LTJiSdEAG4/download/Location%20File.zip HTTP/2
The bandwidth limit is working for you? Because for me NC completely ignore it no matter where I add it.
