example
longer
example
here
System
Nextcloud version (eg, 20.0.5): 25.0.13
Operating system and version (eg, Ubuntu 20.04): Debian GNU/Linux 10 (buster)
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.38
PHP version (eg, 7.4): 7.4.33
The supplied information for the LDAPS server sometimes works (is green and returns the correct number of elements in the base DN) and then does not work for several minutes to hours.
Error: Lost connection to LDAP server.
(and see below).
Raw ldapsearch
works, even when nextcloud-LDAP does not work.
php occ ldap:test-config 'the-config-number'
works and returns The configuration is valid and the connection could be established!
; without intermittent issues.
The Root CA is correctly imported, openssl s_client
works without intermittent issue.
The logs on my LDAP server show (on a failed request from Nextcloud):
ACCEPT from IP=x.x.x.x:58726 (IP=0.0.0.0:7636)
conn=10145 fd=13 TLS established tls_ssf=256 ssf=256
conn=10145 fd=13 closed (connection lost)
the LDAP server logs on a successfull request are as expected.
Logs in nextcloud (with level=0) show only the (correct) LDAP filters, but no information about the connection.
Does anyone have suggestions for further debugging this issue?
Additional Info
Is this the first time you’ve seen this error? Y
?php
'instanceid' => 'xxxxx',
'passwordsalt' => 'xxxxx',
'secret' => 'xxxxx',
0 => 'xxxxxxx',
'trusted_proxies' =>
0 => 'xxxxxx',
1 => 'xxxxxx',
'datadirectory' => '/data/data',
'version' => '25.0.13.2',
'overwrite.cli.url' => 'xxxxxx',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'xxxxxx',
'loglevel' => 2,
'ldapIgnoreNamingRules' => false,
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'dbindex' => 0,
'password' => 'xxxxx',
'timeout' => 1.5,
'log_type' => 'file',
'log_query' => false,
'syslog_tag' => 'Nextcloud',
'logdateformat' => 'F d, Y H:i:s',
'log_rotate_size' => true,
