Nextcloud version (eg, 22.2.0): 22.2.0
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.3 LTS
Apache or nginx version (eg, Apache 2.4.25): 2.4.41
PHP version (eg, 7.4): 7.4
Hello, Just newly installed and trying to setup for LDAP user access. However, it seemed to me that the users assigned to a security group can’t be visible in Nextcloud. I created a AD security group under a new OU, and assigned some existing users in my AD as the members of this security group, i.e.
cn=userGroup,ou=Nextcloud,ou=heterogeneous system,dc=example,dc=com
in LDAP/AD Integration, I set ou=Nextcloud as the base DN… all configuration OK.
I created a new user, say ‘nextcloud.user’ under the ou=Nextcloud. I have selected nested group in Advanced page, but the settings always found only 1 user, i.e. nextcloud.user
Is there way to make all members inside the ‘userGroup’ visible in NextCloud? Your advices and comments are much appreciated. Thanks.
- Setting → LDAP/AD integration
- Then set the config as below:
No specific error with this in the log
The output of your config.php file in /var/www/nextcloud/config (make sure you remove any identifiable information!):
'instanceid' => '*************',
'passwordsalt' => '****************',
'secret' => '***********************',
0 => 'x.x.x.x',
'version' => '22.2.0.2',
'overwrite.cli.url' => 'http://x.x.x.x/nextcloud',
'dbname' => '**********',
'dbhost' => 'localhost',
'dbuser' => '********',
'dbpassword' => '*******',
'skeletondirectory' => '/var/nextcloud_defaultfiles',
'ldapUserCleanupInterval' => 20,
'memcache.local' => '\OC\Memcache\APCu',
-- no specific errors or information during that time.
