example
longer
example
here
Nextcloud version (eg, 20.0.5): 28.0.3
Operating system and version (eg, Ubuntu 20.04): Arch Linux
Nextcloud + Nginx Proxy Manager running in Podman-Docker using these docker-compose files: Nextcloud Docker Setup ($3683489) · Snippets · GitLab
Large uploads are failing with cryptic errors in both the web UI and desktop sync client. I have already increased the PHP upload limit and the Apache body limit by passing the following environment variables to my containers:
PHP_UPLOAD_LIMIT=16G
APACHE_BODY_LIMIT=0
I have also configured Nginx Proxy Manager to disable client_max_body_size and proxy_buffering:
Behavior in Web UI
When I upload a large file (> 3GB) via the Web UI, it will start and at a random point in time fail. In the browser logs, I see
[ERROR] uploader: Chunk 15 146800640 - 157286400 uploading failed
This message is followed by an object saying that the error was an AxiosError
with code ERR_NETWORK
An odd thing I’ve noticed is that sometimes the upload will go through, but then the next upload of large file will almost immediately fail.
Behavior with the desktop sync client
When using the desktop client, it will also randomly fail during the upload, but with the message:
Error while reading: error:0A0003FC:SSL routines::ssl/tls alert bad record mac
The desktop client will occasionally attempt to retry and it will sometimes automatically complete the upload. Other times, I have to manually tell it to sync now.
Is this the first time you’ve seen this error? (Y/N): No
- Setup a Nextcloud instance behind a Nginx Proxy Manager using the official Nextcloud docker images (non-AIO). Docker compose files are provided in this post for reference
- Increase PHP upload_max_limit, etc.
- Upload a large file (> 3GB) and notice that it fails in both the Web UI and desktop client
BadRequest Expected filesize of 2721691545 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 1332592640 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
And it just keeps repeating after every fail.
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => '<redacted>',
'passwordsalt' => '<redacted>',
'secret' => '<redacted>',
0 => 'mydomain.me',
'trusted_proxies' =>
'version' => '28.0.3.2',
'overwrite.cli.url' => 'https://mydomain.me',
'dbname' => 'nextcloud',
'dbhost' => 'db',
'dbuser' => 'nextcloud',
'dbpassword' => '<redacted>',
'mail_smtpmode' => 'smtp',
'mail_smtphost' => 'smtp.gmail.com',
'mail_from_address' => 'mydomain.me',
'mail_domain' => 'gmail.com',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtpport' => '587',
'mail_smtpname' => 'mydomain.me',
'mail_smtppassword' => '<redacted>',
'maintenance_window_start' => 3,
'app_install_overwrite' =>
0 => 'bruteforcesettings',
1 => 'richdocumentscode',
'loglevel' => 2,
'redis' =>
'host' => 'redis',
'password' => '',
'port' => 6379,
'default_phone_region' => 'US',
'theme' => '',
Because these are podman containers, the logs go into journalctl
. Here’s the paste bin: Nextcloud upload fail logs ($3683516) · Snippets · GitLab
Thanks in advance.
