Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): 25.0.04
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.41
PHP version (eg, 7.4): 8.1.16
Redis Container: 7.0.9-debian-11-r1
Microk8s: v1.26.1
The issue:
I am trying to use the multi primary redis cluster (charts/bitnami/redis-cluster at main · bitnami/charts · GitHub" for file locking.
However it leads to errors on file actions such as move or delete.
The Webinterface simply shows messages such as:
Error deleting file "Test".
Could not move "Test"
The apache log shows:
"DELETE /remote.php/dav/files/admin/Test HTTP/1.1" 423 819 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0"
And the nextcloud log shows nothing at all.
Is this the first time you’ve seen this error? Yes
- Install Nextcloud with Ubuntu 20.04, Apache2, PHP 8.0
- Install Redis Cluster with microk8s and bitnami redis cluster helm chart
- Enable Redis Cluster for file locking in config.php
The output of config.php file in /path/to/nextcloud:
'passwordsalt' => 'placeholder',
'secret' => 'placeholder',
0 => 'placeholder',
'version' => '25.0.4.1',
'overwrite.cli.url' => 'http://placeholder',
'dbname' => 'nextcloud',
'dbhost' => '127.0.0.1',
'dbuser' => 'nextcloud',
'dbpassword' => 'placeholder',
'instanceid' => 'placeholder',
'filelocking.debug' => true,
'redis.cluster' =>
'seeds' =>
0 => 'redis-cluster-service-ip:6379',
'timeout' => 0.0,
'read_timeout' => 0.0,
'failover_mode' => 0,
'password' => 'placeholder',
Is anyone familiar with the issue or has a functioning redis cluster that does the file locking?
