Joplin does not sync with NextCloud
LM 21.3 Cinnamon, Edge update
In my older version of Joplin synchronization worked flawlessly with NextCloud.
Got the message that my Joplin version is too old to synch.
I installed an update via the recommended terminal command:
wget -O - https://raw.githubusercontent.com/laurent22/joplin/master/Joplin_install_and_update.sh | bash
Now I have Joplin v. 3.0.14
After installation all looks fine; old data to be seen. However, Joplin does not synch. Neither up to the NextCloud server nor down.
Synchronization settings
Synchronization target: NextCloud
WedDAV URL : path to my NextCloud followed by /remote.php/dav/files/name/JoplinSynch
where “name” is my NextCloud loggin name, " JoplinSynch" is the folder containg the Joplin data
Check synchronization configuration gives following message:
Error. Please check that URL, username, password, etc. are correct and that the sync target is accessible. The reported error was:
path to my NextCloud followed by /remote.php/dav/files/name/JoplinSynch/ failed, reason: (Code ETIMEDOUT)
I re-entered all information several time using for name and password copy&paste => same error message
I can enter my NextCloud via web browser and the NextCloud add-on to Nemo file manager works fine.
What is the problem?
What did I do wrong?
What do I need to check?
What do I need to change?
[/details]
Nextcloud version (eg, 29.0.5): 19.0.12
Operating system and version (eg, Ubuntu 24.04): Linux Mint 21.3 Cinnamon,edge
Apache or nginx version (eg, Apache 2.4.25): don’t know where to find this information
PHP version (eg, 8.3): don’t know where to find this information
Joplin does not synch with NextCloud
  1. set up the synchronization information (see above)
  2. Check the synchronization configuration => time out error (see above)
  3. re-entered all several times to avoid a typo
I don’t know how to do this
I don't know how to get the output.
The output of your Apache/nginx/system log in `/var/log/____`:
I don’t know how to get the output.
I found under .config / nextcloud log files and the latest one contains for the time I worked on the Synchronization set up (I needed to shorten the file was too big)
2024-08-18 11:22:32:979 [ info nextcloud.gui.socketapi ./src/gui/socketapi/socketapi.cpp:362 ]:	Received SocketAPI message <-- "RETRIEVE_FOLDER_STATUS:/home/rost/Nextcloud" from QLocalSocket(0x55bc37734e00)
2024-08-18 11:22:32:979 [ debug nextcloud.gui.socketapi ./src/gui/socketapi/socketapi.cpp:205 ]	[ OCC::SocketListener::sendMessage ]:	Sending SocketAPI message --> "STATUS:OK:/home/rost/Nextcloud" to QLocalSocket(0x55bc37734e00)
2024-08-18 11:22:33:179 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:1069 ]:	<========== Sync finished for folder [Nextcloud] of account [admin2@cloud.sosx.de] with remote [https://cloud.sosx.de/remote.php/dav/files/admin2/]
2024-08-18 11:22:51:054 [ debug nextcloud.gui.account.state ./src/gui/accountstate.cpp:262 ]	[ OCC::AccountState::checkConnectivity ]:	"admin2@cloud.sosx.de" The last ETag check succeeded within the last  30 s ( 23 s). No connection check needed!
2024-08-18 11:22:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:22:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:22:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:22:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:22:56:055 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:922 ]:	Can not run etag job: Polltime not reached
2024-08-18 11:23:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:23:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:23:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:23:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:23:26:054 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 53 s)
2024-08-18 11:23:26:054 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:23:26:054 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "f121198c-5bea-4ea8-961d-46af651c82d3"
2024-08-18 11:23:26:054 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:23:26:054 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:23:28:015 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:23:28:016 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:23:28:016 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:23:53:055 [ debug nextcloud.gui.account.state ./src/gui/accountstate.cpp:262 ]	[ OCC::AccountState::checkConnectivity ]:	"admin2@cloud.sosx.de" The last ETag check succeeded within the last  30 s ( 26 s). No connection check needed!
2024-08-18 11:23:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:23:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:23:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:23:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:23:56:055 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 83 s)
2024-08-18 11:23:56:055 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:23:56:055 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "1c07205f-169f-4070-9fe1-1cc12a88934a"
2024-08-18 11:23:56:055 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:23:56:055 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:23:57:604 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:23:57:604 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:23:57:605 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:24:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:24:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:24:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:24:26:055 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:24:26:055 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 113 s)
2024-08-18 11:24:26:055 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:24:26:055 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "2c4c0963-3303-4f9e-a976-202608af2df6"
2024-08-18 11:24:26:055 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:24:26:056 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:24:28:691 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:24:28:692 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:24:28:692 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:24:55:054 [ debug nextcloud.gui.account.state ./src/gui/accountstate.cpp:262 ]	[ OCC::AccountState::checkConnectivity ]:	"admin2@cloud.sosx.de" The last ETag check succeeded within the last  30 s ( 27 s). No connection check needed!
2024-08-18 11:24:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:24:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:24:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:24:56:055 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:24:56:055 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 143 s)
2024-08-18 11:24:56:055 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:24:56:055 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "d6d83374-00f1-4515-8caa-80c06c525e2a"
2024-08-18 11:24:56:055 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:24:56:056 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:24:57:804 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:24:57:804 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:24:57:805 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:25:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:25:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:25:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:25:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:25:26:053 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 173 s)
2024-08-18 11:25:26:053 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:25:26:054 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "9f32467e-da5f-46bc-b977-46767dab5d9d"
2024-08-18 11:25:26:054 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:25:26:054 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:25:27:700 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:25:27:700 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:25:27:701 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:25:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:25:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:25:56:055 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:25:56:055 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:25:56:056 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 203 s)
2024-08-18 11:25:56:056 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:25:56:056 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "534957e1-e77b-43c5-9a63-abee6f5642e0"
2024-08-18 11:25:56:057 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:25:56:057 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:25:57:053 [ debug nextcloud.gui.account.state ./src/gui/accountstate.cpp:262 ]	[ OCC::AccountState::checkConnectivity ]:	"admin2@cloud.sosx.de" The last ETag check succeeded within the last  30 s ( 30 s). No connection check needed!
2024-08-18 11:25:57:800 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:25:57:800 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:25:57:800 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:26:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:26:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:26:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:26:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:26:26:053 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 233 s)
2024-08-18 11:26:26:054 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:26:26:054 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "8af5d1df-d3d7-4f36-8c9b-3267ac1fe9f8"
2024-08-18 11:26:26:054 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:26:26:054 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:26:28:739 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:26:28:739 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:26:28:739 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:26:56:054 [ debug nextcloud.gui.ocsuserstatusconnector ./src/libsync/ocsuserstatusconnector.cpp:226 ]	[ OCC::OcsUserStatusConnector::fetchUserStatus ]:	Try to fetch user status
2024-08-18 11:26:56:054 [ debug nextcloud.gui.ocsuserstatusconnector ./src/libsync/ocsuserstatusconnector.cpp:229 ]	[ OCC::OcsUserStatusConnector::fetchUserStatus ]:	User status not supported
2024-08-18 11:26:56:054 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	2 "" "https://cloud.sosx.de/ocs/v2.php/apps/notifications/api/v2/notifications?format=json" has X-Request-ID "dafc3bf2-0060-475f-99bd-fbda266c00da"
2024-08-18 11:26:56:054 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/ocs/v2.php/apps/notifications/api/v2/notifications?format=json") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:26:56:054 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::JsonApiJob created for "https://cloud.sosx.de" + "ocs/v2.php/apps/notifications/api/v2/notifications" "OCC::ServerNotificationHandler"
2024-08-18 11:26:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:26:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:26:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:26:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:26:56:054 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 263 s)
2024-08-18 11:26:56:054 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:26:56:054 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "25369007-0dc7-41d3-abd3-48a7b72c96cf"
2024-08-18 11:26:56:054 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:26:56:054 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:26:57:900 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:26:57:900 [ info nextcloud.sync.networkjob.jsonapi ./src/libsync/networkjobs.cpp:881 ]:	JsonApiJob of QUrl("https://cloud.sosx.de/ocs/v2.php/apps/notifications/api/v2/notifications?format=json") FINISHED WITH STATUS "OK"
2024-08-18 11:26:57:900 [ warning nextcloud.sync.networkjob.jsonapi ./src/libsync/networkjobs.cpp:902 ]:	Nothing changed so nothing to retrieve - status code:  304
2024-08-18 11:26:57:900 [ warning nextcloud.gui.servernotification ./src/gui/tray/notificationhandler.cpp:83 ]:	Status code  304  Not Modified - No new notifications.
2024-08-18 11:26:57:900 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::JsonApiJob finished for "ocs/v2.php/apps/notifications/api/v2/notifications"
2024-08-18 11:26:57:901 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:26:57:901 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:26:59:054 [ debug nextcloud.gui.account.state ./src/gui/accountstate.cpp:262 ]	[ OCC::AccountState::checkConnectivity ]:	"admin2@cloud.sosx.de" The last ETag check succeeded within the last  30 s ( 2 s). No connection check needed!
2024-08-18 11:27:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:27:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:27:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:27:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:27:26:054 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 293 s)
2024-08-18 11:27:26:054 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:27:26:054 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "a90af2bd-c156-4ac0-a078-292c47c6847b"
2024-08-18 11:27:26:054 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:27:26:055 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:27:28:411 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:27:28:411 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:27:28:412 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:27:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:27:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:27:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:27:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:27:56:054 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 323 s)
2024-08-18 11:27:56:055 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:27:56:055 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "a3bcf9a2-13b6-4250-9957-43381bef8abf"
2024-08-18 11:27:56:055 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:27:56:055 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:27:58:017 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:27:58:017 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:27:58:018 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:28:01:054 [ debug nextcloud.gui.account.state ./src/gui/accountstate.cpp:262 ]	[ OCC::AccountState::checkConnectivity ]:	"admin2@cloud.sosx.de" The last ETag check succeeded within the last  30 s ( 4 s). No connection check needed!
2024-08-18 11:28:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:28:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:28:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:28:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:28:26:055 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 353 s)
2024-08-18 11:28:26:055 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:28:26:055 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "6c945d96-425c-4b5b-8037-3d3a7b3592e1"
2024-08-18 11:28:26:055 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:28:26:055 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:28:27:630 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:28:27:630 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:28:27:630 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:28:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:28:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:28:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:28:56:055 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:28:56:055 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 383 s)
2024-08-18 11:28:56:055 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:28:56:055 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "d1b99b33-5c50-4f5c-8574-0ec51c2bec5a"
2024-08-18 11:28:56:055 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:28:56:056 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:28:58:205 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:28:58:205 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:28:58:206 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:29:03:054 [ debug nextcloud.gui.account.state ./src/gui/accountstate.cpp:262 ]	[ OCC::AccountState::checkConnectivity ]:	"admin2@cloud.sosx.de" The last ETag check succeeded within the last  30 s ( 5 s). No connection check needed!
2024-08-18 11:29:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:29:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:29:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:29:26:053 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:29:26:054 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 413 s)
2024-08-18 11:29:26:054 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:29:26:054 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "99830431-97d9-4847-8e96-78255e721c28"
2024-08-18 11:29:26:054 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:29:26:054 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:29:27:439 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:29:27:439 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:29:27:439 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:29:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:29:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:29:56:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:29:56:055 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:29:56:055 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 443 s)
2024-08-18 11:29:56:055 [ debug nextcloud.gui.folder.manager ./src/gui/folderman.cpp:696 ]	[ OCC::FolderMan::slotRunOneEtagJob ]:	Scheduling "https://cloud.sosx.de/remote.php/dav/files/admin2/" to check remote ETag
2024-08-18 11:29:56:055 [ info nextcloud.sync.accessmanager ./src/libsync/accessmanager.cpp:78 ]:	6 "PROPFIND" "https://cloud.sosx.de/remote.php/dav/files/admin2/" has X-Request-ID "059b6b9a-bfc6-4302-89b6-658d0f0b9a9f"
2024-08-18 11:29:56:056 [ debug nextcloud.sync.cookiejar ./src/libsync/cookiejar.cpp:90 ]	[ OCC::CookieJar::cookiesForUrl ]:	QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") requests: (QNetworkCookie("__Host-nc_sameSiteCookielax=true; secure; HttpOnly; SameSite=lax; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("__Host-nc_sameSiteCookiestrict=true; secure; HttpOnly; SameSite=strict; expires=Fri, 31-Dec-2100 23:59:59 GMT; domain=cloud.sosx.de; path=/"), QNetworkCookie("oc_sessionPassphrase=ymHafuBjoUjfwQkxAQO3dgaJ41DtZ22HfV5QIiPoamYcAIoDL3BXAK7veS8zUI3OZlf6Mz71ydRn%2FCwDNPr58vI3DshA%2BmpbwfTIaDO%2Faa2OOiCW%2BO2kfsXKsNRnPD%2Fr; secure; HttpOnly; domain=cloud.sosx.de; path=/"), QNetworkCookie("ocpgdjt0k1cn=2670dfc2fd755630e07efe7ebac3e4ba; secure; HttpOnly; domain=cloud.sosx.de; path=/"))
2024-08-18 11:29:56:056 [ info nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:361 ]:	OCC::RequestEtagJob created for "https://cloud.sosx.de" + "/" "OCC::Folder"
2024-08-18 11:29:57:692 [ info nextcloud.sync.credentials.webflow ./src/gui/creds/webflowcredentials.cpp:425 ]:	request finished
2024-08-18 11:29:57:692 [ info nextcloud.sync.networkjob.etag ./src/libsync/networkjobs.cpp:109 ]:	Request Etag of QUrl("https://cloud.sosx.de/remote.php/dav/files/admin2/") FINISHED WITH STATUS "OK"
2024-08-18 11:29:57:693 [ debug nextcloud.sync.networkjob ./src/libsync/abstractnetworkjob.cpp:298 ]	[ OCC::AbstractNetworkJob::slotFinished ]:	Network job OCC::RequestEtagJob finished for "/"
2024-08-18 11:30:05:054 [ debug nextcloud.gui.account.state ./src/gui/accountstate.cpp:262 ]	[ OCC::AccountState::checkConnectivity ]:	"admin2@cloud.sosx.de" The last ETag check succeeded within the last  30 s ( 8 s). No connection check needed!
2024-08-18 11:30:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:867 ]:	Etag poll timer timeout
2024-08-18 11:30:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:871 ]:	Folders to sync: 1
2024-08-18 11:30:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:881 ]:	Number of folders that don't use push notifications: 1
2024-08-18 11:30:26:054 [ info nextcloud.gui.folder.manager ./src/gui/folderman.cpp:898 ]:	Run etag job on folder OCC::Folder(0x55bc37281160)
2024-08-18 11:30:26:055 [ info nextcloud.gui.folder ./src/gui/folder.cpp:331 ]:	Trying to check "https://cloud.sosx.de/remote.php/dav/files/admin2/" for changes via ETag check. (time since last sync: 473 s)
Here I cut of the log file content because it was too big
Your logs give way too much info on your setup fyi.
Is this also you?
Try reading what the other people posted about the same error, since it appears to be a Joplin issue.
Thanks for your reply!!!
Sorry for the long log file. I did not where it really starts repeating.
#v-13-0-4-in-does-not-synch-in-linux-mint/39418/)
yes that’s me as well.
I hope for a solution urgently.
The logs you posted seem to be for the Nextcloud Desktop client, but the Joplin setup instructions suggest it uses its own built-in WebDAV client. So I think you’re looking in the wrong place for the problem.
Are you really using Nextcloud Server 19.0.12 (!?). That version has been end-of-life for multiple years: Maintenance and release schedule — Nextcloud latest Administration Manual latest documentation
Thanks for your reply.
Although it does not provide the solution, it is helpful in terms that I know now that the problem is on the Joplin side.
Old version - My brother is the admin and I asked him to get us a new one.
Thanks for the hint.
The previous folder name was “Joplin” - maybe the Joplin folder on your server needs to be created new or the old one to be renamed to “JoplinSynch” (case-sensitive!).
Be sure to backup such directories before messing with their sync status.
You’ll want to make a backup of all your Nextcloud data before the upgrade, just in case.
Thanks for your kind reply!
Joplin - folder
I used since start a folder called “JoplinSynch” it worked always but I will try to see if a change will help.
New Version
I reached out to my brother and he says that it is not possible to update our old version anymore. So I am thinking about a parallel installation of new version and then transfer all the staff over in a step by step action.
However you triggered question:
How can an upgrade be made for our old version to a new one? If so, to which version?
How can an backup of all be made on the server before making an NextCloud upgrade?
It is totally possible.
You or your brother will need to do research as all of these questions have been answered. Search the forum and the internet or read docs.nextcloud.com
If you still need help you can open tickets for those particular things since the Joplin question is answered. Thanks.
Thanks for reply and hints
